TheBearJew
- Nov 4, 2022
Hi all,
Happy New Year.
I'm able to successfully replicate datasets, but not zvols. Can you all help me with this? I've spent 6 hours trying, what's felt like, everything under the sun, but have had no success.
Here are the steps that I'm doing in order to recreate the issue. First my process for datasets.
Now, lets try zvols.
Thanks
TheBearJew
Happy New Year.
- Plug in external drive.
- Go to Storage Dashboard and Create Pool (I'm wanting to backup my datasets and VM's to external disk/zfs pool)
- Name Pool "WesternDigitalBackup" - Enable Encryption - Create disk as single stripe - Create Pool - Download encryption key - Done.
- Go to Datasets
- Add Dataset to WesternDigitalBackup - Example:TEST. (My Tank-Rust pool has a dataset named TEST with random data)
- Encryption set to Inherit, Share Type set to SMB - Done.
- Go to Data Protection
- Add replication task
- Source Tank-Rust/Test - Destination WesternDigitalBackup/Test - Next
- When Run Once -Make Destination Dataset Read-only? YES - Save
- Process is running, check Datasets, data has copied, SUCCESS
- Go back to step 4.
- Add Zvol on WesternDigitalBackup - Zvol name "WindowsTest-16eiki" (this was the name for the VM under Tank-Rust) - Size 80GiB (same as Tank-Rust) - Block size set to Inherit, everything else left as default. - SAVE
- Source Tank-Rust/VirtualMachines/WindowsTEST-16eiki - Destination WesternDigitalBackup/WindowsTEST-eiki - Next
- When Run Once -Make Destination Dataset Read-only? NO - Save
- ERROR message "Unable to send encrypted dataset 'Tank-Rust/VirtualMachines/WindowsTEST-16eiki' to existing unencrypted or unrelated dataset 'WesternDigitalBackup/WindowsTest-16eiki'."
- P.S. If I go back to datasets the zvol that I created under WesternDigitalBackup is indeed encrypted, it is "Unlocked by ancestor".
Thanks
TheBearJew
