Vishimtar
- Nov 17, 2014
My Freenas BOX: FreeNAS Build FreeNAS-9.10.2-U3 (e1497f269) versions Hardware is OEM Computer box Intel (R) Core (TM) i3 CPU 540 @ 3.07GHz Gigabyte Technology Co., Ltd. Motherboard Model: H55M-S2H 8GB DDR3 Memory 4 X Western Digital Red 3TB HDD ZFS Raid Group and FreeNAS 1x 250GB hdd install
In my first installation, the prompt was working entirely with components on the onboard. There is a raid group consisting of ZFS Raid group 4x 3TB WD Red NAS hhds.
ZFS had to repair a raid disk, I changed the disk and repaired it worked fine after a long time started to fail again This time I started to get the ATA Control error, so I changed the SATA cables and power supply
I replaced the defective disk with a new one again and ZFS sync process started and I saw my data in the ZFS raid group I started to get ATA Control error this time under the load while the sync process was going on and the process stopped because the ZFS raid group saw it and therefore the same name system was not included After closing the FreeNAS box, removing the ZFS Raid disks and opening them again
I deleted the zfsraid group defined via the web gui and chose not to delete the data in the Raid Group. I closed the system and reintroduced the ZFS Raid group disks into the system, this time disks SATA controller: Marvell Technology Group Ltd. 88SE9230 PCIe SATA 6Gb / s Controller (rev 11) PCI SATA controller connected and plugged in the disks
I turned on the system and all the disks look right hardware but I can't import the ZFS Raid group.
I used the zpool import -FX zfsraid command in the import transaction. After 2 days of operation, the server restarts and the operation fails. For now, gpartitions appear on disks in glabel, but I can't import zfsraid because I can't do anything to the newly included disk.
ZFS Raid structure and some system outputs
Can you help, how can I recover the data here?
GpartShow
GpartList
Glabel Status
Camcontrol List
smartctl -a /dev/ada0
smartctl -a /dev/ada1
smartctl -a /dev/ada2
smartctl -a /dev/ada3
Thank you.
GpartShow
=> 34 5860533101 ada1 GPT (2.7T) 34 94 - free - (47K) 128 4194304 1 freebsd-swap (2.0G) 4194432 5856338696 2 freebsd-zfs (2.7T) 5860533128 7 - free - (3.5K) => 34 5860533101 ada2 GPT (2.7T) 34 94 - free - (47K) 128 4194304 1 freebsd-swap (2.0G) 4194432 5856338696 2 freebsd-zfs (2.7T) 5860533128 7 - free - (3.5K) => 34 5860533101 ada3 GPT (2.7T) 34 94 - free - (47K) 128 4194304 1 freebsd-swap (2.0G) 4194432 5856338696 2 freebsd-zfs (2.7T) 5860533128 7 - free - (3.5K) => 34 488397101 ada4 GPT (233G) 34 1024 1 bios-boot (512K) 1058 6 - free - (3.0K) 1064 488396064 2 freebsd-zfs (233G) 488397128 7 - free - (3.5K)
GpartList
Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: b0a83cc6-d8f2-11e8-9d6b-1c6f6521f14f rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: b0b64d6e-d8f2-11e8-9d6b-1c6f6521f14f rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: af28cad4-d8f2-11e8-9d6b-1c6f6521f14f rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada2p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: af37ce9a-d8f2-11e8-9d6b-1c6f6521f14f rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada2 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada3 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: ae7be949-d8f2-11e8-9d6b-1c6f6521f14f rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada3p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: ae8bab76-d8f2-11e8-9d6b-1c6f6521f14f rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada3 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 ------------------------------------------------------------------------------ Geom name: ada4 modified: false state: OK fwheads: 16 fwsectors: 63 last: 488397134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada4p1 Mediasize: 524288 (512K) Sectorsize: 512 Stripesize: 0 Stripeoffset: 17408 Mode: r0w0e0 rawuuid: 95745a9f-acf6-11e8-98c9-1c6f6521f14f rawtype: 21686148-6449-6e6f-744e-656564454649 label: (null) length: 524288 offset: 17408 type: bios-boot index: 1 end: 1057 start: 34 2. Name: ada4p2 Mediasize: 250058784768 (233G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 544768 Mode: r1w1e1 rawuuid: 957c5fa1-acf6-11e8-98c9-1c6f6521f14f rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 250058784768 offset: 544768 type: freebsd-zfs index: 2 end: 488397127 start: 1064 Consumers: 1. Name: ada4 Mediasize: 250059350016 (233G) Sectorsize: 512 Mode: r1w1e2
Glabel Status
Name Status Components gptid/b0a83cc6-d8f2-11e8-9d6b-1c6f6521f14f N/A ada1p1 gptid/b0b64d6e-d8f2-11e8-9d6b-1c6f6521f14f N/A ada1p2 gptid/af37ce9a-d8f2-11e8-9d6b-1c6f6521f14f N/A ada2p2 gptid/ae7be949-d8f2-11e8-9d6b-1c6f6521f14f N/A ada3p1 gptid/ae8bab76-d8f2-11e8-9d6b-1c6f6521f14f N/A ada3p2 gptid/95745a9f-acf6-11e8-98c9-1c6f6521f14f N/A ada4p1 gptid/af28cad4-d8f2-11e8-9d6b-1c6f6521f14f N/A ada2p1
Camcontrol List
<WDC WD30EFRX-68EUZN0 82.00A82> at scbus0 target 0 lun 0 (pass0,ada0) <WDC WD30EFRX-68EUZN0 80.00A80> at scbus1 target 0 lun 0 (pass1,ada1) <WDC WD30EFRX-68N32N0 82.00A82> at scbus2 target 0 lun 0 (pass2,ada2) <WDC WD30EFRX-68N32N0 82.00A82> at scbus3 target 0 lun 0 (pass3,ada3) <Marvell Console 1.01> at scbus7 target 0 lun 0 (pass4) <WDC WD2502ABYS-50B7A1 02.03B06> at scbus9 target 0 lun 0 (pass5,ada4)
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD30EFRX-68EUZN0 Serial Number: WD-WCC4N3ZAKJN9 LU WWN Device Id: 5 0014ee 2bc0386bd Firmware Version: 82.00A82 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Mar 16 13:04:41 2020 +03 SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (39120) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 393) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 3 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 69 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 0 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 74 194 Temperature_Celsius 0x0022 122 118 000 Old_age Always - 28 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD30EFRX-68EUZN0 Serial Number: WD-WMC4N1279182 LU WWN Device Id: 5 0014ee 2b47b2e4f Firmware Version: 80.00A80 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Mar 16 13:04:52 2020 +03 SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (41640) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 418) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 181 176 021 Pre-fail Always - 5950 4 Start_Stop_Count 0x0032 098 098 000 Old_age Always - 2096 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 083 083 000 Old_age Always - 13011 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1234 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 128 193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 3683 194 Temperature_Celsius 0x0022 124 098 000 Old_age Always - 26 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 188 000 Old_age Always - 302 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD30EFRX-68N32N0 Serial Number: WD-WCC7K0SNCAYC LU WWN Device Id: 5 0014ee 2ba2c5d36 Firmware Version: 82.00A82 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Mar 16 13:05:20 2020 +03 SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (30780) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 328) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 168 166 021 Pre-fail Always - 6600 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 64 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 11124 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 63 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 27 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 61 194 Temperature_Celsius 0x0022 123 111 000 Old_age Always - 27 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD30EFRX-68N32N0 Serial Number: WD-WCC7K2PX8H0H LU WWN Device Id: 5 0014ee 264d6cb2c Firmware Version: 82.00A82 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Mar 16 13:05:47 2020 +03 SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (32400) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 345) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 168 168 021 Pre-fail Always - 6558 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 55 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 11101 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 55 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 31 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 48 194 Temperature_Celsius 0x0022 124 109 000 Old_age Always - 26 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
Thank you.
