hi,
I am setting up a NAS box with the following hardware.
Atom D525 Mobo
Adaptec 3805 4x PCIe card
4x 2 Tb SATA drives
System on CF card (With CF to SATA adapter)
4 Gb RAM
I am considering using 64 bit Freenas 8. I am now considering the file system to use and I am not keen on using UFS (Have spent to much time already in my life on endless fschk on UFS and old Ext systems) so the I am left with ZFS. My question is now what is the best strategy to use for the underlying RAID array. Should I just put the controller in JBOD mode and use RAIDz for redundancy? Or should I use RAID 10 on the controller and just format this as ZFS in Freenas? Or RAID 5 on the controller and RAIDz as file system? There are many options but I don't like the idea of "RAID on RAID", have bad experiences with this from before in other OS.
I am not so concerned with speed (will be enough for what I need any how) or space (I can live with having 3.6 Tb of space which is what I get from a RAID 10 array). my main concerns is stability (both filesystem and the OS itself) and some redundancy. With a Linux box I would have used RAID10 and Ext3, that would be a good setup for me, but I am lost with with ZFS here.
Thank you
/Bob
Atom D525 Mobo
4x 2 Tb SATA drives
4 Gb RAM
Thank you
/Bob
