Hello Forum,
I just built a new system to replace a Freenas 7 system that was not up to the task of running ZFS and Lion. So I put together a build of all new components and was eager to get Freenas 8 running.
I had attempted to install FreeNAS-8.0.2-RELEASE-amd64.iso, but kept hitting a Fatal Trap 12 error.
I decided to jump to a more recent FreeNAS-8.2-r8878-amd64 and was able to install and run this version with no errors.
However I am now having trouble creating a dataset. I created a volume of four 1TB HDD with no issue. The problem is Freenas will not let me do anything with the volume. I can not change permissions, or create a dataset, create a snapshot - I just get an error pop up box. The only thing I can do, is scrub volume.
The volume status indicates all drives are online.
Any thoughts?
Any thoughts?
