SOLVED ZFS not showing up
0ut1awed
SOLVED! I can't believe I missed this. Of course you can drag the icon vertically as well as horizontally.....
So I have 4 x 2TB Seagate NAS drives in my setup. Even so I can't seem to get the option to put the drives in a ZFS Raid....
I think this might be linked to my extremely sub-par mobo (MSI P55M-P33) and the fact that they are all plugged up directly into that board. Not sure.
Any suggestions? Thanks!
Dusan
Drag the slider horizontally to get a single row of 4 disks. RAIDZ1 & RAIDZ2 should then appear in the drop-down.
0ut1awed
Yea, I figured that out like 10 minutes after I posted it and then edited in above. So dumb of me...
Anyways, I appreciate the response!
