I would like to begin with thanking everyone who is taking the time to read this thread. Without further ado:
I recently had a disk go offline, but I got it back online with a reseat and had to resliver the pool. During the resliver,the disk became 'removed'. It kept on progressing, so I though it was fine. A bit later the pool showed up in storage, but with no zvols or shares under it. I detached it, and tried to reattach to no avail, so I had the bright idea to reboot during the resliver, to see if it would fix it, and forums suggested that would be fine.
Now, the situation is this:
I attempted a force mount based on another forum using:
What I don't understand (Other than this being my fault) is how in mirror-0 both disks are online but it shows 'corrupted data.'
Mirror-1 only has 1 disk, as the other went removed, but the other disk shows online but the mirror is again corrupted.
Also, all the disks are online as far as I can tell:
ada0-3 are the disks in this particular pool.
These disks are encrypted (Beginning in FreeNAS 11 it has not been too bad of an experience), but that is not an issue. My recovery key unlocks the drives.
I do not have a backup (Future aspiration) and the data is not critical (In the sense I am not losing money), however it would probably take a week to recover from this and ~8TB would need to be recovered, so I would like to avoid that if possible.
EDIT: Silly me. I did not include the hardware information. I knew I would forget something.
FreeNAS Build: FreeNAS-11.1-U5
Motherboard: Gigabyte GA-B150M-DS3H
CPU: Intel Celeron G3900
RAM: 32GB DDR4 (8 by 4) (32610MB)
HDDs: 4x 6TB WD Red Pros (In this specific pool) RAID 0 + 1
Motherboard SATA controller is in use.
iSCSI: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Fibre: QLogic Corp. ISP2432-based 4Gb Fibre Channel to PCI Express HBA
/end edit
I can provide any additional information as requested. I did not think of anything else to gather initially. I greatly appreciate any help. This is also my first ever forum post on the internet, so go easy!
root@freenas:~ # zpool import pool: HDD id: 11250748561142489606 state: FAULTED status: One or more devices were being resilvered. action: The pool cannot be imported due to damaged devices or data. The pool may be active on another system, but can be imported using the '-f' flag. config: HDD FAULTED corrupted data mirror-0 FAULTED corrupted data gptid/a2eb439b-19c9-11e7-9e0f-408d5cc6e5d1.eli ONLINE gptid/a8cfb85d-fad0-11e6-9551-408d5cc6e5d1.eli ONLINE mirror-1 FAULTED corrupted data 9994001295554260855 UNAVAIL cannot open gptid/ddf1c8e2-76d7-11e8-b59d-408d5cc6e5d1.eli ONLINE root@freenas:~ # zpool status HDD cannot open 'HDD': no such pool
root@freenas:~ # zpool import -fFX HDD cannot import 'HDD': one or more devices is currently unavailable
root@freenas:~ # glabel status Name Status Components gptid/723ae9a4-2c13-11e8-85a9-408d5cc6e5d1 N/A da0p1 gptid/a8cfb85d-fad0-11e6-9551-408d5cc6e5d1 N/A ada0p2 gptid/a2eb439b-19c9-11e7-9e0f-408d5cc6e5d1 N/A ada1p2 gptid/ddf1c8e2-76d7-11e8-b59d-408d5cc6e5d1 N/A ada2p2 gptid/b7d0542d-d4c2-11e7-951c-408d5cc6e5d1 N/A ada3p2
/end edit
