I want to thank you all for your help. I was able to test my plan successfully. I found it easier to do this mainly from the command line using the zfs commands instead of the GUI.
My next step to determine which FreeNAS device to use (Mini or something more powerful). Since the VMs on the public network are only used to receive updates, I am assuming the Mini will suffice. The VMs on the private network will be used by end users, so I am assuming the 1U FreeNAS server will be needed.
