geronimo
- Jul 20, 2012
Guys, I will try to keep it very short as I tend to get into unnecessary details.
My ultimate goal is to choose between using 512n, 512e, or pure 4kN drives for a new ZFS storage appliance that will either consist of eight 4TB drives in four mirror VDEVs, or eventually Raidz2 in order to mitigate any unrecoverable read errors that might occur during re-silvering a mirror in case of disk failure.
I understand the difference between 512n, 512e and 4kN drives and that 512e drives are basically 4k sector drives with emulation for backward compatibility for software that supports only 512b sectors. I know that with 4k drives there is more efficiency as there is eight times less gaps between sectors and eight times less markers.
Still it is quite difficult for me to make a decision on which drives to choose from as with HGST (Ultrastar 7k6000 SAS) I can choose between 512n, 512e and 4kN and with Seagate (Enterprise Capacity 3.5 SAS) I can choose between 512e and 4kN).
One of the things that bothers me given the fact that ZFS will always use the physical sector size to create VDEVs is if there would be any difference between using 512e and 4kN drives from the same model when using these in ashift=12 vdevs? My understanding here is that ZFS treats 512e and 4kN drives the same way in such vdevs and my guess is that any operations involving pure 4k reads and writes from and to 512e drive would not cause any in-drive processor usage e.g. causing performance degradation which is the case when using the drive in 512e mode. Would I be right to assume that?
I am trying to figure out if there is any reasoning behind getting pure 4kN drives that would get another 15% on top of my bill as opposed to 512e drives.
On the other side of the coin, having the option from HGST to choose 512n 4TB drives I am trying to figure out if that would be of any benefit other than optimizing overhead for certain file sizes in RaidZ setups. And I do understand that 512n drives could be little bit slower due to the higher number of operations needed to acquire sectors.
Any opinions are highly appreciated!
~Cheers~
~Cheers~
