ZFS and 4K
Suiname
SSH to the box and run:
zdb -C BackupMainVol1 | grep ashift
12 means that its 4k :)
Alright, mine came back with ashift: 9, so I guess that means I'm not running 4k. Can I change the block config without destroying the volume? The thread seems to suggest I can't.
Nope. Gotta destroy the zpool and recreate it :(
pete_c20
I can run this on 8x 500GB WD RE3 with a native 512byte/sector. However I get the following error: Can not open temp file: iozone.tmp open: Read-only file system
I haven't had any problems with the volume being read only in other testing. I though it might by a permissions problem so set the volume permissions to root & wheel but it made no difference.
Anybody know what's going on?
You have to have write permissions to perform all of the tests as desire in post #1.
pete_c20
It comes as no surprise that I would have to have the write permissions to do it. I thought that in the shell, as root, or by using sudo that I would be able to do that. I understand the basic concept of permissions attached to directories and files, but after several days of trying to pick it up I can't properly marry permissions to what I see in the GUI. Something still hasn't dropped into place for me yet.
So unless somebody would be kind enough to talk me through that one, sadly I'll have to skip this. I don't have the time to spend several more days trying to do it.
paleoN
You need to change the directory before running the command:
cd /mnt/tank
iozone -r 4k -r 8k -r 16k -r 32k -r 64k -r 128k -s 6g -i 0 -i 1 -i 2
Edit: snipped
pete_c20
Thank you paleoN. After trying to figure out what 'tank' was and then filling the filesystem above it :rolleyes: with the 8K test, we're now up and running in the right place. You know, that problem and a pointer as to where to find the answer, maybe the most important learning for some days. :D. Will report back with some results. It seemed a shame, when I've a system sat here that's about to be put into use, that it couldn't be used to bring some useful data to the community.
pete_c20
Finally some test data. Firstly, thankyou to PaleoN for a much needed pointer as to how to kick it all off, without which these results would not of appeared. Thankyou to the OP for raising this question in what for me was a very pertinent time, and as a noob commissioning a new system, where my upgrade/maintainence path is important to me, and just in time for me to take 4K into account.
The following system was used and this next paragraph details the constants:
Supermicro X9SCM-F v2.0b BIOS with an E3-1220Lv2 @ 2.3GHz Xeon. 16GB ECC DDR3 uDIMMs with a FreeNAS hardware tunable to limit it to 4GB as per the OP. SATA PCIe HBA card is an LSI9211-8i (LSI00194) flashed with p15 IT firmware with the BIOS disabled, and is the sole card in the motherboard. All drives hang off this card where 8 drives are concerned. For the 10 disk test the extra 2 are plugged into the motherboard.
FreeNAS version: 8.3.0 Rel p1 x64 (r12825) Compression = off. Dedup=off.
All HHDs used are identical, they are Western Digital WD 5002ABYS 512bytes/sector native, 500GB, RE3, 7200rpm, 16MB cache with their orginal and still current firmware v02.03B02. Their sustained large file single drive transfer rate (datasheet & observed) is 112MByte/sec. Drives have no links installed to limit their speed.
IOZONE command line: iozone -r 4k -r 8k -r 16k -r 32k -r 64k -r 128k -s 6g -i 0 -i 1 -i 2. Always from command line.
Now for the variables, and some notes on the specific tests:
A couple of aborted tests suggested a small variation in results from re-running the same test, but a very quick look suggested it was usually small (ie not worse than the 3rd most significant digit). I leave that to IOZONE.
Test #1 & #2 hopefully address the OP's question. Test #3,#4 & #5 are variations to answer my own questions and hopefully maybe of use to others.
For tests #1 thru #4 'atime=on'. For test #5 'atime=off'. Further reading, during testing, suggested that enabling 'atime' may significantly impact read performance, so I ran test #5 at the end with it off. This last test would directly compare with test #2.
Test #3, the 10disk RAIDZ2 test, was to satisfy my own curiosity as to what performance impact an optimal (2/4/8 disks + 2 parrots) ZFS Z2 configuration had over what maybe deemed to be a non-optimal Z2 configuration, ie where the number of data disks are not a power of 2.
Tests #3,#4 & #5 were not performed in 512bytes/sector mode due to lack of time, and also 512bytes/sector will likely become a thing of the past.
The IOZONE test results.
Test #1. ZFS configuration: 8disks in (6+2) RAIDZ2. Force 4K sectors disabled. (2.6TB volume reported size.)
                                                   random  random
     KB  reclen   write  rewrite    read   reread    read   write
6291456       4  344044    90934  139417   149958     648     554
6291456       8  382535    95971  147316   158259    1274    1091
6291456      16  406700   103767  145246   152340    2507    2140
6291456      32  468023   101219  154310   156147    5421    4164
6291456     128  429458   336491  152566   158256   14551  410136
Test #2. ZFS configuration: 8disks in (6+2) RAIDZ2.Force 4K sectors enabled. (2.5TB volume reported size)
                                                   random  random
6291456       4  335485    87068  135491   145476     646     557
6291456       8  385966    92489  150878   148586    1184    1092
6291456      16  388087    96794  141227   148081    2518    2154
6291456      32  423178    97766  145405   148634    5103    4137
6291456     128  399557   318293  147168   161375   15142  421706
Test #3. ZFS configuration: 10disks in (8+2) RAIDZ2.Force 4K sectors enabled. (3.7TB volume reported size)
                                                   random  random
6291456       4  335500    97198  148482   159965     636     557
6291456       8  435407    99014  145315   148184    1267    1100
6291456      16  473380   105504  149504   172862    2415    2141
6291456      32  389674   108700  148647   158314    5375    4182
6291456     128  562781   372510  161167   169586   14058  552917
Test #4. ZFS configuration: 8disks in ((2+2)x2) RAIDZ2 Force 4K sectors enabled.(1.7TB volume reported size.)
                                                   random  random
6291456       4  291322    75182  112847   120848     728     611
6291456       8  308598    76628  118592   135213    1371    1208
6291456      16  307889    84520  119768   128726    2845    2355
6291456      32  304571    82985  120782   123981    6101    4597
6291456     128  327061   304220  126189   130475   15924   20443
Test #5. ZFS configuration: 8disks in (6+2) RAIDZ2.Force 4K sectors enabled.(2.5TB volume reported size)
N.B. atime = off, for this test only
                                                   random  random
6291456       4  331861    91151  135052   145138     643     554
6291456       8  339839    93089  140074   144900    1187    1091
6291456      16  286186    94953  154224   154341    2498    2142
6291456      32  363436    98116  147924   161909    4726    4096
6291456     128  407814   330602  146010   152179   14640  380474
Note to others running the same test; run it from the command line as once the GUI crashed after being left overnight. Test time was about 10-12 hours and about 7+ of those were the 4K random read/writes.
It would be great if somebody could graph this lot, and perhaps even the other thread results, to present the data in a more effective way.
My conclusion:
1) Tests #1 & #2 suggest that 'Force 4K' on these 512bytes/sector HDDs slows the throughput a little but not by much. At a guess about 2%-3% worst case.
2) I'm not worried about the impact (if any?) of 'atime' on speed.
3) Test configuration #4 didn't make the system faster as I thought it would by producing 2vdevs, I'm wondering if that was down to a boo boo by me? Unfortunately I can't repeat these tests as the system is now in use.
4) Neither did the 10 disk 'optimal' configuration speed the show up, apart from random reads of larger files.
Your thoughts please.
I'm sure that after this, that the platters on my hard drives are that little bit thinner :smile:.
jgreco
Resident Grinch
Nicely presented even if it veered a bit off-request.
I think that the reasonable conclusion is that 4K does hurt some people with 512 native drives, sometimes, but not by such a big margin as to take a system from "usable" to "unusable." I think my worst case was maybe a 10% loss. The potential benefits of 4K for future pool expansions is probably a major consideration. I kind of wish we'd hear back from ixSystems on how these results are being interpreted by the FreeNAS team.
