System Hardware:
CPU: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (2500.14-MHz K8-class CPU)
Real memory = 35165044736 (33536 MB)
mps0: <LSI SAS2308> port 0x2000-0x20ff mem 0xda240000-0xda24ffff,0xda200000-0xda23ffff irq 16 at device 0.0 on pci3
mps0: Firmware: 16.00.00.00, Driver: 16.00.00.00-fbsd
mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
There are 16 disks in a raid10 like setup of this:
da0 at mps0 bus 0 scbus0 target 8 lun 0
da0: <TOSHIBA MG03SCA200 0108> Fixed Direct Access SCSI-5 device
da0: Serial Number 45D0A02LFZZ9
da0: 600.000MB/s transfers
da0: Command Queueing enabled
da0: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C)
Benchmark command: dd if=/dev/daXX of=/dev/null bs=262144
Single HD performance:
Aggr HD performance:
I am not an expert but this seems like my LSI card limited the bandwidth to 50Mbs per drive?
ZFS Test. Compression disabled for tests, the rest paremeters are default. All tests done locally on the NAS, no iSCSI or NFS involved.
I guess all this parameters look normal except for the rewrite, is this normal?
[root@nas01] ~# iostat da16 1
tty da16 cpu
tin tout KB/t tps MB/s us ni sy in id
0 135 112.83 50 5.49 0 0 2 0 97
0 133 128.00 1279 159.89 0 0 0 0 100
0 48 128.00 1298 162.21 0 0 0 0 99
0 47 128.00 1303 162.84 0 0 0 0 100
0 48 128.00 1304 162.96 0 0 0 0 99
0 47 128.00 1299 162.34 0 0 1 0 99
0 47 128.00 1281 160.09 0 0 0 0 100
0 48 128.00 1281 160.09 0 0 0 0 99
0 47 128.00 1325 165.58 0 0 1 0 99Aggr HD performance:
[root@nas01] ~# iostat da16 da17 da18 da19 da20 da21 da22 da23 da24 da25 da26 da27 da28 da29 da30 da31 1
tty da16 da17 da18 da19 da20 da21 da22 da23 da24 da25 da26 da27 da28 da29 da30 da31 cpu
tin tout KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s us ni sy in id
0 135 112.40 49 5.38 112.30 49 5.37 112.29 49 5.37 112.37 49 5.36 112.45 49 5.38 112.35 49 5.36 112.33 49 5.39 112.39 49 5.37 112.43 49 5.38 111.73 50 5.42 112.49 49 5.34 112.66 49 5.38 112.69 49 5.37 112.57 49 5.38 112.52 49 5.36 112.44 49 5.36 0 0 2 0 97
0 912 128.00 386 48.22 128.00 387 48.34 128.00 387 48.34 128.00 386 48.22 128.00 383 47.84 128.00 379 47.35 128.00 392 48.97 128.00 401 50.09 128.00 387 48.34 128.00 381 47.59 128.00 391 48.84 128.00 403 50.34 128.00 381 47.59 128.00 377 47.10 128.00 382 47.72 128.00 393 49.09 0 0 2 0 97
0 315 128.00 388 48.45 128.00 381 47.58 128.00 402 50.20 128.00 386 48.20 128.00 383 47.83 128.00 384 47.95 128.00 395 49.33 128.00 397 49.58 128.00 396 49.45 128.00 381 47.58 128.00 391 48.83 128.00 385 48.08 128.00 387 48.33 128.00 381 47.58 128.00 375 46.83 128.00 384 47.95 0 0 2 1 97
0 315 128.00 394 49.20 128.00 395 49.33 128.00 406 50.70 128.00 394 49.20 128.00 385 48.08 128.00 396 49.45 128.00 384 47.95 128.00 381 47.58 128.00 376 46.95 128.00 386 48.20 128.00 381 47.58 128.00 390 48.70 128.00 382 47.70 128.00 383 47.83 128.00 375 46.83 128.00 390 48.70 0 0 3 0 97
0 315 128.00 383 47.83 128.00 380 47.45 128.00 396 49.45 128.00 381 47.58 128.00 384 47.95 128.00 389 48.58 128.00 387 48.33 128.00 389 48.58 128.00 381 47.58 128.00 387 48.33 128.00 398 49.70 128.00 399 49.82 128.00 375 46.83 128.00 387 48.33 128.00 389 48.58 128.00 392 48.95 0 0 2 1 97
0 315 128.00 383 47.83 128.00 398 49.70 128.00 386 48.20 128.00 391 48.83 128.00 394 49.20 128.00 381 47.58 128.00 388 48.45 128.00 396 49.45 128.00 390 48.70 128.00 383 47.83 128.00 388 48.45 128.00 388 48.45 128.00 382 47.70 128.00 393 49.08 128.00 376 46.95 128.00 380 47.45 0 0 2 2 97
0 315 128.00 385 48.08 128.00 400 49.95 128.00 382 47.70 128.00 394 49.20 128.00 385 48.08 128.00 379 47.33 128.00 394 49.20 128.00 392 48.95 128.00 407 50.82 128.00 390 48.70 128.00 393 49.08 128.00 378 47.20 128.00 378 47.20 128.00 391 48.83 128.00 378 47.20 128.00 372 46.45 0 0 2 1 97
0 315 128.00 381 47.58 128.00 401 50.07 128.00 384 47.95 128.00 395 49.33 128.00 383 47.83 128.00 389 48.58 128.00 387 48.33 128.00 396 49.45 128.00 390 48.70 128.00 390 48.70 128.00 382 47.70 128.00 384 47.95 128.00 379 47.33 128.00 385 48.08 128.00 390 48.70 128.00 381 47.58 0 0 2 1 97
0 315 128.00 388 48.45 128.00 386 48.20 128.00 388 48.45 128.00 384 47.95 128.00 385 48.08 128.00 390 48.70 128.00 399 49.83 128.00 385 48.08 128.00 393 49.08 128.00 387 48.33 128.00 383 47.83 128.00 402 50.20 128.00 384 47.95 128.00 375 46.83 128.00 376 46.95 128.00 391 48.83 0 0 3 0 97
0 315 128.00 386 48.20 128.00 386 48.20 128.00 376 46.95 128.00 386 48.20 128.00 378 47.20 128.00 389 48.58 128.00 387 48.33 128.00 390 48.70 128.00 390 48.70 128.00 391 48.83 128.00 405 50.57 128.00 386 48.20 128.00 387 48.33 128.00 386 48.20 128.00 381 47.58 128.00 393 49.08 0 0 2 1 96I am not an expert but this seems like my LSI card limited the bandwidth to 50Mbs per drive?
[root@nas01] /mnt/tank# iozone -r 4k -r 8k -r 16k -r 32k -r 64k -r 128k -s 64g -i 0 -i 1
Iozone: Performance Test of File I/O
Version $Revision: 3.420 $
Compiled for 64 bit mode.
Build: freebsd
Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins
Al Slater, Scott Rhine, Mike Wisner, Ken Goss
Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,
Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,
Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,
Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,
Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,
Vangel Bojaxhi, Ben England, Vikentsi Lapa.
Run began: Sun Aug 23 00:39:31 2015
Record Size 4 KB
Record Size 8 KB
Record Size 16 KB
Record Size 32 KB
Record Size 64 KB
Record Size 128 KB
File size set to 67108864 KB
Command line used: iozone -r 4k -r 8k -r 16k -r 32k -r 64k -r 128k -s 64g -i 0 -i 1
Output is in Kbytes/sec
Time Resolution = 0.000001 seconds.
Processor cache size set to 1024 Kbytes.
Processor cache line size set to 32 bytes.
File stride size set to 17 * record size.
random random bkwd record stride
KB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread
67108864 4 272495 47919 529063 508837
67108864 8 261976 49975 581346 650581
67108864 16 265560 50986 599449 650338
67108864 32 279449 51662 631565 656612
67108864 64 263125 52159 641028 667229
67108864 128 303179 307754 645718 665924 I guess all this parameters look normal except for the rewrite, is this normal?
