N00BYSL4Y3R
- Mar 19, 2017
Hello
I've never done a FreeNAS machine before and I'm really excited to do my first one.
It will be primary used for backing up my and family data.
I'll also want it to be used as a Plex media server capable of transcoding 1080p to at least 3 clients at the same time without problems.
Ive done some research already about the hardware and did a build based on the hardware recommendation guide R1c I found here.
I would like some of you who had experience with to review my build and say if everything's ok and maybe give me some suggestions and what not
CPU: I3-6300 3.8ghz Dual core
Motherboard: AsRock C236 WSI mini Itx
RAM: Crucial 16GB (1 x 16GB) DDR4-2133 ECC
OS Storage: Sandisk ReadyCache 32GB 2.5" SSD
Storage: 4x WD Red 4TB 5400rpm
PSU: SeaSonic Snow Silent 750W 80+ Platinum
Case: Fractal Design Node 304 Mini ITX (white)
So, do I need to change anything?
Thanks!
Thanks!
