X11SSL-F 2400MHz DIMMs
yacenty
Guys, can You confirm that X11-ssl-f can handle 4 ram modules on 2400mhz?
I have an issue and can not run 4x16gb 2400mhz with xeon e3-1230v6
DrKK
FreeNAS Generalissimo
I don't understand the question. Are you asking if the board supports a memory speed of 2400 MHz? Or if the board supports 16GB DIMMs?
yacenty
Both combined, with 4 modules.
I bought this stuff, but I can not run 4x16gb /2400mhz.
I'm starting to build up a server.
I have such a devices:
MB: SuperMicro X11SSL-F
CPU: e3-1230v6
RAM: Samsung 4x16GB 2400 UDIMM ECC.
I had build up the PC, run it and I hear 5 short beeps and one long.
now there is other issue
the system works only with 2 memory slots occupied - so only 32GB ram.
If I put 3.rd or 4th ram stick the system can not boot.
I get such error exactly:
0x09=mrcDataTimeCentering1DErr
I can only occupy the 2 first slots from the top (black and blue). More I had described here: https://forums.freenas.org/index.ph...ssl-f-problem-with-boot-up.63660/#post-456083 so please connect those topics in one.
