Chuck Munro
- Jan 3, 2016
I am experiencing a mysterious issue with WireGuard Client to be installed on three NAS systems .... two of them are FreeNAS 11.3-U5 and one is TrueNAS Core 12.
My aim is to replace OpenVPN running in a jail, with WireGuard running on the main platform. I am doing the primary test installation on one of the FreeNAS 11.3-U5 machines. If I can make it work correctly I can get rid of the jails.
The WireGuard packages install correctly (wireguard-go and wireguard tools), and the VPN starts and runs after following the instructions in various posts here. The client picks up its correct IP address from the WireGuard server (on a Linux machine). Reboots restart WireGuard correctly, as expected.
The client conf file:
[Interface]
Address = 10.8.0.5/24
ListenPort = 33094
PrivateKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[Peer]
PublicKey = yyyyyyyyyyyyyyyyyyyyyyyyyyy
PresharedKey = zzzzzzzzzzzzzzzzzzzzzzzzzzz
AllowedIPs = 10.8.0.0/24
PersistentKeepalive = 10
Endpoint = server_fqdn:33094
But after connecting and configuring ok, the problem starts ... I can't ping or SSH to any other machines on the VPN, but pings and SSH work fine via the same VPN among the other non-FreeNAS machines (Linux and macOS). Pings in both directions between the VPN server and the FreeNAS client fail silently, and SSH just hangs.
Netstat seems to report routing is ok:
Internet:
Destination Gateway Flags Netif Expire
default 192.168.10.1 UGS re0
10.8.0.0/24 wgvpn45 US wgvpn45
10.8.0.5 link#4 UH wgvpn45
127.0.0.1 link#3 UH lo0
192.168.10.0/24 link#2 U re0
192.168.10.45 link#2 UHS lo0
192.168.50.0/24 link#1 U em0
192.168.50.45 ink#1 UHS lo0
All traffic for the other two interfaces (re0 and em0) works correctly, but I can't send or receive anything on net 10.8
The WireGuard config for wgvpn45 has a PersistentKeepalive parameter set to 10 seconds, just in case.
Ipfw reports nothing should stop packets: ' 65535 allow ip from any to any ', and I have net.inet.ip.forwarding set to 1 in the System Tunables GUI.
So ... I must be missing something or I've made a dumb mistake somewhere. Does anyone have any ideas or perhaps seen the same issue?
Thanks in advance for any assistance you can offer,
Chuck
[Interface]
ListenPort = 33094
[Peer]
Internet:
Chuck
