Wireguard: How to access LAN resources through wireguard from remote laptop?
picklefish
I followed this guide: https://www.ixsystems.com/blog/wireguard-on-freenas-11-3/
Turned on IP Forwarding: https://docs.freebsd.org/doc/4.4-RELEASE/usr/share/doc/en_US.ISO8859-1/books/ppp-primer/x237.html
When I try to setup the route by adding my LAN ip range to the wg0.conf the wireguard start fails because I already have that ip range on the igb0 interface
 netstat -rn
Routing tables
Internet:
Destination        Gateway            Flags     Netif Expire
default            192.168.1.1        UGS        igb0
10.200.200.1       link#6             UH          wg0
10.200.200.2/32    wg0                US          wg0
127.0.0.1          link#3             UH          lo0
192.168.0.0/16     wg0                US          wg0
192.168.1.0/24     link#1             U          igb0  # THIS LINE
192.168.1.234       link#1             UHS         lo0
My server config looks like this:
[Interface]
PrivateKey = xxxx
Address = 10.200.200.1/24
ListenPort = 34567
[Peer]
PublicKey = xxxx
AllowedIPs = 10.200.200.2/32, 192.168.0.0/16 # THIS GUY
I want 192.168.0.0/16 to be 192.168.1.0/24 (which fails due to the route on igb0 I believe)
I am pretty sure I just don't understand routing well enough. Could anyone point me in the right direction.
Thank you
elrodvt
Have you tried 0.0.0.0 in wg's allowed ip list to see if that works. I'm struggling with a similar issue from jails. Opening allowed ip did not work for me fwiw. But I don't really have much of a clue to what's wrong.
