Will It FreeNAS with Gigabyte GA-990FXA-UD3
HARIT
Hi All,
I am pretty new to FreeNAS and NAS in general. I am thinking of building a FreeNAS instead of buying. I am considering of buying a used a machine.
I came across a few. Below is the config for the ones i am thinking of buying. It will be around 100-150 euros.
First machine:-
Gigabyte GA-990FXA-UD3 Sli
Am3 + socket
CPU And phenom 980x 3.7ghz quad core
64gb ssd
250gbg hdd
Nocthua Cpu cooler
R7 240 2gb ddr3 graphics card HDMI
8gb ddr3 frame
Second Machine:-
Hp pavilion P6
I5 2310 3ghz quad core
500gb had
8gb ddr3 ram
Ari hd 7 series low profile 1gb ddr3
Drives:-
WD RED drives:- 3 TB (2)
What i want to acheive:-
FreeNAS, opencloud and Plex server for media sharing and streaming
Can any of the machine will be able to handle? I can expand the ram to 16 gb if thats the bottle neck.
Or is there any option to buy a standalone nas for the same price?
Sorry for a lot of question, i am abit confused how to procced. How somebody can help:)
Inxsible
None of those support ECC RAM. Although it will work without ECC, it is not recommended. Since you are going to buy it, I would advise you to buy proper server hardware instead of buying desktop grade parts.
Also 8GB is the minimum required to run FreeNAS. You would need more to run plugins like Plex, etc.
You don't need a GPU for FreeNAS other than for the initial install. If you have IPMI, usually available only on server grade hardware, you don't need the GPU even for the install as you can use IPMI.
Have you read the Hardware Recommendations Guide yet?
HARIT
Thank you for the super fast reply.
I have a HP z400 workstation as my home computer i think could it fit
Here is the config:-
Manufacturer HP, Inc
Type
Enterprise Workstation
Processor
Intel Xeon W3520
Number of Cores
Quad-Cores
Memory
12GB DDR3
Storage
2TB HDD
Video
GTX1050TI 4gb
Operating System
Windows 10
Optical Drive
Yes
Network
Gigabit Ethernet
Chris Moore
Any system you buy for that little money will not be worthy of running FreeNAS. Just because the name has FREE in it doesn't mean that you can run it on any old junk you can find.
You need to review the hardware guide:
Hardware Requirements
http://www.freenas.org/hardware-requirements/
FreeNAS® Quick Hardware Guide
https://forums.freenas.org/index.php?resources/freenas®-quick-hardware-guide.7/
Hardware Recommendations Guide Rev 1e) 2017-05-06
https://forums.freenas.org/index.php?resources/hardware-recommendations-guide.12/
Then take a look at these resources:
Slideshow explaining VDev, zpool, ZIL and L2ARC
https://forums.freenas.org/index.ph...ning-vdev-zpool-zil-and-l2arc-for-noobs.7775/
Terminology and Abbreviations Primer
https://forums.freenas.org/index.php?threads/terminology-and-abbreviations-primer.28174/
If you are still with it after that, have a look at this:
Updated Forum Rules 4/11/17
https://forums.freenas.org/index.php?threads/updated-forum-rules-4-11-17.45124/
Did you read the manual?
http://doc.freenas.org/11/freenas.html
