Does autotune set new value for L2ARC ? i enabled it, then after i added a cache disk. if i disable it, then re-enable it, will it write new value with my cache in consideration ?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
