wraith
 - Dec 21, 2015
Hi All,
Hope all had a Merry Christmas and a Happy NYE!
I've recently had a 42U rack installed at home. I have little to no experience with using rack-mounted chassis' and see this as an opportunity to try my hand. However, being new to all this, I want to start off with an inexpensive non-production system [currently considering a backup system]. I've been doing some technical and sales research and reaching out to the community for feedback as to whether my plan is feasible/practicable and any tips to ease the learning curve and ensure I'm on the right track.
I've found a second hand HP Storageworks X1600 G2 that someone is selling for around AUS$350 [~US$275]. I've been doing some research and this appears to have potential. The spec's for this are:
Notes I've made:
I would appreciate any feedback/advice on:
Please let me know if there is anymore information I need to track down and provide to assist.
Thanks in advance for your assistance and time
- CPU: Xeon E5520. Passmark ~4400. Supports upto 144Gb ECC RAM;
 - M/B: HP custom. Can support upto two Xeon chips.
 - CONTROLLER: HP Smart ArrayP212/512MB Controller with BBWC (LFF front drive slots)
 - BAY'S: 12 x 3.5" at front; 2 x 2.5" at rear. The 2.5" at rear are, I understand, intended to act in mirror for the OS;
 - NIC: HP NC362i Integrated Dual Port Gigabit Server Adapter;
 - RAM: 12 bays. Being sold with 16Gb DDR ECC RAM. Size and quantity of modules unknown
 - EXPANSION: 1 x x16 PCI-Express [half length/half height]; 1 x x8 PCI-Express [full length/full height - used by the P212
 - POWER: 750W with Redundant
 - MORE: https://h10057.www1.hp.com/ecomcat/hpcatalog/specs/provisioner/99/BV862A.htm
Notes I've made:
- The E5520 is LGA1366. I've been able to find LGA1366 boards on ebay should the one with the unit fail. The only potential issue is whether it will fit, the existing being a custom board;
 - I've seen it mentioned around the forum that some controller's have a 2Tb limit. Not sure if the P212 has this limitation [refer below];
 - I may need to setup the controller to allow FreeNAS to control the disks directly;
 - Availability and pricing of SuperMicro parts in Western Australia leaves something to be desired
- Firstly, is this even a good idea or feasible? Has anyone tried to install FreeNAS on this, or similiar, server?
 - Anything in particular I should take note of when inspecting or testing a second hand chassis. There are some items I consider obvious such as checking the bays work, physical size. Looking at advice on any small details that may trip me up should the above proceed
 - I'm a little confused by the specifications for the SA P212 controller. The spec's stat 24Tb maximum [for the entire server ie 2Tb per drive] but it's not clear to me if this is due to HDD sizes back at the decade's beginning or a limit on the card itself. I've seen some reference to 3Tb drives against this controller. However, mention is also made about support for drives in excess of 2Tb via logical drive. Is anyone familiar with this device to assist in interpreting the spec's? I'm assuming that if it's the card, this can be replaced with a suitable, current controller. Spec's for the P212 here.
