Just thought I would post my experiences with 'open box' hardware.
I recently bought some external hard drives from my local computer store. I fully intended on pulling them from their enclosures and running them internally in the end. Some of them were 'open box' and discounted 5%. I got them home, and was surprised how easy it was to get smartctl to access them. Simply adding "-d sat" was enough. Running smart tests even worked through the usb bridge.
One of the 'open box' drives had 109 power on hours. And according to smart, had previously exceeded it's recommended operating temperature. Here's the relevant smart info:
Note, that it's now at 198 power on hours, but was already at 109 when I powered it up the first time. Also, the UDMA crc error count was me. Guess I had a bad cable. When I cabled it up internally and booted freenas, I got a whole bunch of command time-outs. Changing the sata cable completely fixed the timeouts.
But most disturbingly is the failed "in the past" of the temperature. At some point 'in the past' it has exceeded it's operating temperature. I *think* seagate defines 60C as max operating temperature. So all I know is that this drive has gotten hotter than that, assuming it is a max of 60.
I called my local computer store, and talked to a manger. He explained that 'open box' means that a customer has purchased the item, brought it home and 'used it' for up to 7 days. Then brought it back and 'returned it' for whatever reason. The computer store's tech's then 're-qualifies' it, and they sell it as 'open box'.
To me, this is definitely more like 'used' than 'open box'. And certainly not worth a measly 5% off.
On the other hand, the same computer store has 'refurbished' items that are sold 20-50% off. These are items that the customer has brought back, the computer store has determined that they are faulty, and they return them to the manufacturer. When the manufacturer repairs / replaced them and the computer store receives the replacement, they sell it as refurbished. Depending on the item, I'll take a chance on this kind of deal. Much better discounts, and it's "manufacturer refurbished", and not "local computer store used".
It's interesting that my definition of 'open box', where the box is 'opened' in-store, but the product has never been purchased or 'used' by a customer, the computer store here sells as "new". But their definition of 'open box' to me is actually a 'used' product, way beyond just being 'open box'.
Anyway, I'll see how the drive behaves. I probably could have gotten my money back for the 'open box', but I just didn't want to bother. I definitely won't be buying any more 'open box' deals from that particular store though. Wanted to throw out a warning to check what 'open box' means before buying anything.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 118 100 006 Pre-fail Always - 189285288 3 Spin_Up_Time 0x0003 092 092 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 43 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 069 060 030 Pre-fail Always - 4303945311 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 198 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 36 183 Runtime_Bad_Block 0x0032 099 099 000 Old_age Always - 1 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 099 000 Old_age Always - 0 0 3 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 072 035 045 Old_age Always In_the_past 28 (0 17 32 22 0) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 23 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 319 194 Temperature_Celsius 0x0022 028 065 000 Old_age Always - 28 (0 17 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 190 000 Old_age Always - 462 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 107h+56m+47.537s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 6068438234 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3637637284 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 154 -
