- Mar 6, 2014
At least it's not NetBurst.It just means you're a "power user" :p
If you're going with supermicro motherboards, you should look at X9 single-processor boards (which I believe will be sandy/ivybridge). Once you find something interesting post a link here and get some comments from the peanut gallery. When in doubt, consult intel spec sheets for chipsets and processors to make sure they both support ECC memory.As along as you guys support purchasing used hardware.
The hardware on your suggested hardware thread is very rare on eBay, from what the last two weeks of searching has to say anyway.... Time to start looking for suitable hardware myself i suppose. Is there anything else specific that a Motherboard should have in terms of capabilities and spec other than CPU support of anything after Nehalem, have Intel NIC or NIC's and Intel SATA controller?
All my servers are using Intel Xeon 5500/5600 product family, which I believe is Westmere... Guess that just makes me "old school"... :(
Means your gear is "old crap." :)
Been called a lot of titles Architect, Engineer, Tier III, Administrator, etc... I just prefer "geek".Well that would make sense i suppose, what is your job line?
Dell PowerEdge C2100/FS12-TY 2U Servers... Cheap, old, quiet and pretty darn dependable (like me, 'cept for the dependable part..)Also what make are you a fanboy of then?
We work from home:What do you guys have your servers and 'network gear' for at home?
This may be a personal question that you don't wish to answer, which I wont mind if you don't. What do you guys have your servers and 'network gear' for at home? Do you have it all running in a live setup providing a service/use or is it there for 'tinker/messing' or just for the 'fun' of things to play with?
I'm a sysadmin for a business telecom provider, used to be in the NOC for said company (I've been here way too long).This may be a personal question that you don't wish to answer, which I wont mind if you don't. What do you guys have your servers and 'network gear' for at home? Do you have it all running in a live setup providing a service/use or is it there for 'tinker/messing' or just for the 'fun' of things to play with?
