nullReference
- Dec 13, 2013
I am in the process of building a FreeNAS box and want to make sure I have all my "ducks in a row" before hand. I was originally going to go with an onboard hardware raid 5 solution but the more I read about FreeNAS and ZFS I'm not sure if that's the route I wish to take anymore, hints this post.
When I first started researching I was going to go with a dedicated raid controller card because if there was ever an issue with the motherboard I could replace the motherboard and my data would be unaffected (or at least recoverable). RAID 5 was chosen because I liked the idea of being able to hot swap a failed drive with a new one and have it re-propagated automatically.
As time went on however I decided to use the onboard raid controller in a RAID 5 setup and chance the issue of motherboard failure. But then after a bit more research I heard of some people running a software RAID configuration through FreeNAS that was comparable to a hardware RAID 5. The specs for the machine that I am building are as follows:
>Gigabyte AMD 970 mobo (supports onboard RAID 0/1/5/10)
>AMD Sempron 2.8ghz (will be unlocking 2nd core)
>4gb 1333mhz DDR3
>3 1tb sata 3 drives
Knowing these specs my question is then which solution would be the best as far as ease of replacement if something were to fail. Say I have a motherboard failure and require the replacement of the board, what would be the pros/cons of hardware vs software in this situation?Redundancy is more important to me at this point then performance and taking into account that this box will only be used by me to store critical business files, speed is not my greatest concern.
Any thoughts and opinions on this are greatly appreciated!
>4gb 1333mhz DDR3
>3 1tb sata 3 drives
