Where is txz for 9.2???
dniq
Have I missed something? Downloads page only has ISO image, which I can't use (I don't have any CDs or CD drives).
warri
It's available on the normal download page: http://www.freenas.org/download-freenas.html
dniq
It never occurred to me that it would be in "Legacy and 32-bit downloads"...
Thanks!
Then I guess you should download the image file per the manual using the link available at freenas.org. This is easy.... and if you are getting stuck figuring this out FreeNAS is probably not for you.
D
dlavigne
Guest
That page is currently in flux as it's being redesigned to (eventually) make things easier to find...
Ok.. on that basis.. go to iso.cdn.freenas.org and you should be able to navigate the directories easily to find what you want. :)
