Hello I have a problem that TrueNAS CORE system won't boot - it happenned on two machines. It stops at some point I can login as root without a password and services are running, and the serial console showed some errors with middlewared.
Perhaps I messed up with the system was because I enabled pkg FreeBSD repository and performed pkg update and installed pkg byobu
Anyway how can I see what was the reason? I mean some error message or anything that would point out why the system did not start?
Although I worked around the problem by "reinstalling-upgrading" the system - i.e. TrueNAS installer chose if I want to upgrade an existing installation and create a new boot environment, it imported the database and in the new boot environment everything seemed to work again, with previous settings preserved (I didn't check all but I they exists) - except that I don't have the byobu pkg installed anymore. But I would like to switch to the failed boot environment and find the reason so that I avoid in the future.
If the pkg update/install byobu is the reason, then perhaps the problem is that /etc is kind of a temporary file system? I'm not into details but perhaps it is not preserved? I don't know.
But perhaps the problem is somewhere else?
So is there any log for that? So that when the system starts partially and I have the root login (without providing password) then i can diagnose what the problem is?
