SOLVED What's causing a drop of performance ???
NinthWave
I rarely transfer a lot of data but tonigh, I ripped some DVDs and BD and when I wanted to transfer them to my NAS, I realized that the transfer speed for a single file started at 100 MB/s, which seems normal for a 1Gb/s NIC, but dropped at 15-25 MB/s which I find really slow. The scenario repeats itself for each single file.
Also, if I try to transfer a batch of 2-3 files, then the write speed is below 15MB/s for each file.
How can I investigate to source of that: network, lack of memory for buffer ???
ChrisRJ
How are your disks connected?
To separate the network from the storage dimension you should test them separately. For the network side I would use "iperf" and for storage "fio".
NinthWave
NinthWave
I am not sure or to perform th "fio" test. I would not want to mess all my system performing a test. I have found this:
But a more directed help would be appreciated if possible.
NinthWave
Anyone would follow on this please?
ChrisRJ
Can you elaborate what the problem is?
NinthWave
Hello Chris,
As stated in my original post, if I transfer a single file, the datarate from my PC to my TN Core is around 115MBs which I believe is normal on a Gb lan.
I just ripped three 4K movies and started the transfer to my media library.
After about 3 minutes of 115 MBs of sustained througput, the transfer has dropped to around 15MBs and I don't know how to isolate the problem.
Samuel Tai
How is your pool configured, and how much RAM do you have in your system?
NinthWave
I think most of the info is in my signature.
What else can I provide concerning the pool? Is there an "ouptput" I could use to best describe the thing ?
I just ran a backup from a Proxmox VM on an NFS share and it was even slower.
Samuel Tai
What's the output of zpool status <name of your pool>? How full is your pool? zpool get capacity <name of your pool>.
NinthWave
truenas% zpool status Bassin
  pool: Bassin
 state: ONLINE
  scan: scrub repaired 0B in 1 days 02:32:52 with 0 errors on Thu Feb  2 04:33:34 2023
        Bassin                                          ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/3fc56edc-7243-11eb-a7fc-842b2b51538a  ONLINE       0     0     0
            gptid/b84df4dd-f29a-11ec-98d9-842b2b51538a  ONLINE       0     0     0
            gptid/3ffedd3a-7243-11eb-a7fc-842b2b51538a  ONLINE       0     0     0
            gptid/41060316-7243-11eb-a7fc-842b2b51538a  ONLINE       0     0     0
            gptid/4131db70-7243-11eb-a7fc-842b2b51538a  ONLINE       0     0     0
errors: No known data errors
truenas% zpool get capacity Bassin
NAME    PROPERTY  VALUE  SOURCE
Bassin  capacity  31%    -
John Doe
maybe check with iperf if your network is having issues
check cpu load while transfer on client and server
assuming you use windows, maybe check task manager -> performance CPU, network, Disk business
what nic is in your client?
looking at your signature, i am a bit confused, you are mixing 2 and 4 tb drives?
Samuel Tai
OK, what you're seeing is the write bandwidth of the slowest drive in your RAIDZ2 pool. You may benefit by adding a log SSD to your pool, to offload the write log from your pool disks. Note, your log SSD should have power loss protection. Optanes make good log VDEVs.
NinthWave
I made my initial install with 4X 2TB HDD that were already in my Windows PC plus 1 new 4TB knowing that I would not get the full capacity until all 5 disks were 4TB. One 2TB has since showed SMART warning and have been upgraded to 4TB.
How can it sustain the througput for a few minutes and not just a few seconds ?
What would be a suggested capacity for such an Optane? Please consider all 5 drives are 4TB which is where it will get to.
NinthWave
I sadly realized that although I only ordered Red Pro drives, one of them is an SMR drive: WD40EFAX
Can it be source of the problem?
Samuel Tai
NinthWave
Yes, that's the drive with the lowest write bandwidth.
This drive is not that old in terms of hours but if I remember my readings about SMR, they are to be avoided at all costs...
So I guess I should be replacing this drive instead of going the Optane's log way ?
To safely replace that drive (with a CMR) is definitely your best bet.
FYI: Your signature is not correct. You don't have all Red "Pro" drives. The WD40EFAX is a 4TB WD Red. (Not Red Plus. Not Red Pro.)
