I'm looking for a UPS to protect by fresh FreeNAS build. I've never owned a UPS before, so I'm not familiar with caveats and tradeoffs associated with this purchase. Anyway, I've heard good things about APC in this forum and others, and since I can source them locally it seems like a good choice. I have a few questions, though:
- For a given power, they have models in tower and block format. The latter's battery can be replaced by the user. Is this something worth having, or do batteries last such a long time in normal conditions that the UPS is likely to fail for other reasons before one needs to replace the battery?
- In the models without user-serviceable battery, is the battery still a discrete unit which can be replaced by the vendor's representative?
- I checked the NUT compatibility database, but it only says how the driver was derived, not the level of support. Is the APC Back-UPS line (not Pro) well supported in FreeNAS Corral?
- How much headroom should I plan for the power output? Suppose my system consumes 350W max. Would a 400W output be enough?
