jsmith8954
- Jun 9, 2011
Ok, so i set up a test box with a simple share of 1 HD and got everything working.
Now, I'm about to build a production NAS to put on my network. I've already got all the parts including 4 WD 1TB Blue drives. I intend on using the built in software raid-z.
I'm curious how others did their similar setups, and what exactly do i need to set up?
I can get the volume created, but what is the best configuration. I know raid-z has an option for a "spare" drive, etc.
I guess what i'm asking is that, what do I need to configure to ensure that if i loose a disk (i'm sure i will at some point) that i will not loose data, and that i can replace the drive an allow freeNAS to "rebuild" the data?
Thanks in advance!
Thanks in advance!
