This is driving me crazy, FreNAS 8.0.2 Release / AMD64)
I have my top level ZFS volume /mnt/tank exported
I have a dataset below that /mnt/tank/dataset
The dataset permissions in the GUI are 777
The parent folder /mnt/tank is 777
The dataset at the command line is 777
The owner/group is admin:guest
When I mount from a FreeBSD system (mount -t nfs 10.0.0.10:/mnt/tank /mnt/tank),
ls -ld on the FreeBSD client shows 755
I can create and do whatever to other files/directories, but when I try to do anything in the dataset folder /mnt/tank/dataset it shows up empty!
All the directories in that dataset are 777 admin:guest
All the directories in the parent /mnt/tank are 777 admin:guest
Even with permissions of 755 on the client I should be able to list the directory.
I'm familiar enough with this stuff that I shouldn't be having this problem, does anyone have an idea?
Here's the line from /etc/exports:
/mnt/tank -alldirs -mapall=admin:guest -network 10.0.0.1/24
It's just the one bloody folder with the dataset
Oh, the dataset from the client looks like this:
drwxr-x-r-x 2 root guest 2 Aug 6 23:15 dataset
