NFS mapall Ignored
Flash619
Greetings, I am trying to get NFS working on a new FreeNAS 11 RC3 install. The client I will be using to test is running KDE Neon User Edition LTS.
After setting up NFS, once mounted (with nfs4 disabled), all datasets appear to be owned by root:root. If I enable nfs4, the correct permissions are shown, but ls is broken "input / output error" as well as when trying to create files of any kind.
/etc/exports
/mnt/tank/nas  -alldirs -mapall="nobody":"nobody" 192.168.1.60
Client Mount
Flash619@office-pc:/mnt/nfs$ sudo mount -t nfs nas:/mnt/tank/nas /mnt/nfs/nas/
Flash619@office-pc:/mnt/nfs$ ls -la /mnt/nfs/nas/
total 15
drwxrwx--- 7 nobody nogroup  7 Jun  7 16:21 .
drwxr-xr-x 3 root  root	  4096	Jun  7 16:45 ..
drwxr-xr-x 2 root root 2 Jun  7 16:20 dataset1
drwxr-xr-x 2 root root 2 Jun  7 16:20 dataset2
drwxr-xr-x 2 root root 2 Jun  7 16:19 dataset3
drwxr-xr-x 2 root root 2 Jun  7 16:21 dataset4
drwxr-xr-x 2 root root 2 Jun  7 16:19 dataset5
As you can see, the directory containing the datasets is properly set to nobody:nogroup. However none of these permissions are correct on the directories within this folder. Here is the same command from on the NAS itself.
Datasets On Nas
[root@nas ~]# ls -la /mnt/tank/nas/
total 23
drwxrwx---  7 nobody  nobody  7 Jun  7 14:21 .
drwxr-xr-x  4 root		 wheel	  4 Jun  7 16:25 ..
drwxrwx---  2 nobody  nobody  2 Jun  7 14:20 dataset1
drwxrwx---  2 nobody  nobody  2 Jun  7 14:20 dataset2
drwxrwx---  6 nobody  nobody  6 Jun  7 16:02 dataset3
drwxrwx---  2 nobody  nobody  2 Jun  7 14:21 dataset4
drwxrwx---  2 nobody  nobody  2 Jun  7 14:19 dataset4
I'm not really sure what could be going wrong at this point. So any input could be helpful. I will try to give as much info as possible. As I've said, nfs4 has errors as well, so whichever would be the easiest to fix is likely what I will end up using.
EDIT
While I did not get nfs3 working, I did find my issue with nfs 4.
It seems you cannot mount the parent directory of datasets and still access the dataset. This is because a dataset is seen as a separate file system (which it is) and as such is technically not mounted within the parent. The fix was to export each dataset individually and mount with /ets/fstab to make my life easy.
