Share with system-wide permissions
-Adam-
Hi!
I'm struggling with my project which is installing a mail-server (mailinabox) on a share from Freenas. What I want to achieve is to connect a share via fstab and install all the necessary components there. The problem is that when I do mount the share I have only one user and one group (root as default) for the entire share. Mail server uses many different users and combination of access privileges.
Could sb please provide a solution for using a Freenas share with possibility of using system-wide permissions as well?
I use this stab entry to mount:
//192.168.2.13/MAIL /home/user-data cifs username=**,password=**,vers=3.0,mfsymlinks,nobrl,_netdev  0  0
These are the original permissions:
drwxr-xr-x 2 root      root      4096 Feb  7 16:56 backup
drwxr-xr-x 3 root      root      4096 Feb  7 16:49 dns
drwxrwxr-x 7 root      www-data  4096 Feb  7 18:52 mail
-rw-r--r-- 1 user-data user-data    3 Feb  7 16:43 mailinabox.version
drwxrwx--- 5 www-data  www-data  4096 Feb  7 18:17 owncloud
drwxr-xr-x 3 root      root      4096 Feb  7 16:53 owncloud-backup
-rw-r--r-- 1 root      root        15 Feb  7 17:00 settings.yaml
drwxr-xr-x 3 root      root      4096 Feb  7 16:58 ssl
drwxr-xr-x 3 user-data root      4096 Feb  7 16:52 www
And this is how it looks after copying to mounted share:
drwxr-xr-x 2 root root  0 Feb  7 16:56 backup
drwxr-xr-x 2 root root  0 Feb  7 16:49 dns
drwxr-xr-x 2 root root  0 Feb  7 18:52 mail
-rwxr-xr-x 1 root root  3 Feb  7 20:13 mailinabox.version
drwxr-xr-x 2 root root  0 Feb  7 18:17 owncloud
drwxr-xr-x 2 root root  0 Feb  7 16:53 owncloud-backup
-rwxr-xr-x 1 root root 15 Feb  7 20:13 settings.yaml
drwxr-xr-x 2 root root  0 Feb  7 16:58 ssl
drwxr-xr-x 2 root root  0 Feb  7 16:52 www
Thanks,
Adam
