Ok, let me explain my situation.
When I first built my NAS, I used an old Sandisk Cruzer as boot drive. But then I saw several problems with the USB ( write errors / read errors etc.. ).
So I backed up my configuration, and reinstalled system on 2 Sandisk Cruzer Fit drives with mirroring.
The thing is backup was from 9.3...
And the new system is 9.10..
While it accepted the backup, it gave a lot of DB errors/warnings.. But it restored the system to its' previous state..
I was also using an SSD for the jails I use. Well, as far as I see the jails are still based on 9.3
I wouldn't make it a problem if system would still work like before.. But when I tried to compile a port it gave me an error that version doesn't match..
I executed portsnap fetch update & extract again.. But the error persists..
Is there an easy way to upgrade jail to latest version or should I install a new jail and import the settings from old one. It took about a week to build everything for that jail ( Sickrage/Couchpotato/Deluge etc.. ). So, I'm not fond of rebuilding the jail from beginning. But I want to expand my current jail and unfortunately because of port problem it doesn't seem to be possible.
BTW, I should have upgraded via WebUI maybe but it was not an option when the system is almost down. Could there be any side effects restoring 9.3 DB to 9.10? Could I expect a stable system after this or do you recommend starting over from Initial setup and importing zpools, and setting up shares?
