HungrySkelly
- Nov 20, 2020
Hi all,
I successfully upgraded from FreeNAS 11.3 to TrueNAS 12.0 RELEASE a month or two ago. The upgrade itself went off without a hitch, and on the whole everything has been ticking along as if nothing ever happened.
However, there has been one issue that I have noted. On a roughly weekly basis (anywhere between ~5 and 10 days) the webUI has crashed. Jails and services work normally and I can ssh in as per usual.
When logging in via ssh, the following message appears:
I've tried searching online but haven't found anyone with a similar issue (perhaps I'm using the wrong keywords).
Does anyone else have this problem?
Any ideas as to what could be causing it?
(I restart the whole server to restore the WebUI access)
