penguin_brian
- Feb 10, 2021
This *was* working and I have not made any changes:
Meanwhile the box is still up and running, I can still ssh as non-root, etc. Although commands like "top" will hang.
Guessing a reboot might help. As I can't find anyway of getting root access, might be the only option in fact.
But wondering what on earth is going on here?
Later: seems like my boot USB device is dead. Not sure why this should cause problems on running system though. My understanding was that the boot device is only used for booting...
Just wondering what is the best way tor recover?
dmesg shows:
Can't mirror the boot device because (a) can't access website (b) probably can't mirror SUSPENDED pool anyway.
What is the best way to proceed?
Maybe the "Boot the installer with virtualbox and install onto new USB then swap it with the old stick" method? https://www.truenas.com/community/t...able-usb-for-my-freenas-box.73944/post-513198
brian@canidae:~$ curl -v https://minion.pri/ * Trying 2001:44b8:4112:8a03::c:443... * Connected to minion.pri (2001:44b8:4112:8a03::c) port 443 (#0) * ALPN, offering h2 * ALPN, offering http/1.1 * successfully set certificate verify locations: * CAfile: /etc/ssl/certs/ca-certificates.crt * CApath: /etc/ssl/certs * TLSv1.3 (OUT), TLS handshake, Client hello (1): [no response]
brian@canidae:~$ ssh root@minion.pri
Last login: Wed Jan 26 09:52:16 2022 from 2001:44b8:4112:8a02:e88:d16b:f1f6:c2ed
FreeBSD 12.2-RELEASE-p10 b26f74b5984(HEAD) TRUENAS
TrueNAS (c) 2009-2021, iXsystems, Inc.
All rights reserved.
TrueNAS code is released under the modified BSD license with some
files copyrighted by (c) iXsystems, Inc.
For more information, documentation, help or support, go here:
http://truenas.com
Welcome to TrueNAS
[delay]
File "/usr/local/sbin/hactl", line 171, in <module>
main(args.command, args.q)
File "/usr/local/sbin/hactl", line 17, in main
client = Client()
File "/usr/local/lib/python3.9/site-packages/middlewared/client/client.py", line 283, in __init__
[no response, no prompt]
dmesg shows:
[...] (da4:umass-sim0:0:0:0): CAM status: CCB request completed with an error (da4:umass-sim0:0:0:0): Retrying command, 0 more tries remain (da4:umass-sim0:0:0:0): READ(10). CDB: 28 00 00 6e 1a 8c 00 00 80 00 (da4:umass-sim0:0:0:0): CAM status: CCB request completed with an error (da4:umass-sim0:0:0:0): Error 5, Retries exhausted Solaris: WARNING: Pool 'boot-pool' has encountered an uncorrectable I/O failure and has been suspended. [...]
