WEB UI : "Access from your IP is restricted" (mistakes were made)
Clemesis
HI !
I "play" with Truenas for about a year now with a lot of fun ! I use it for storage and run some applications for a media server.
I was trying to make Tailscale work (it wasn't immediatly, and I was tickling around), I tried to "authorize IP" in a settings menu that I don't remember.
When I applied the IP of Tailscale for my distant machine, the service rebooted.
Then the Truenas UI was unaccessable from any machines. All the applications runs, no problem, I can access them.
I just locked myself out of the web UI of Truenas Scale.
Is there a solution maybe from the CLI or something else ?
I would love not to do a factory reset :D
Clemesis
morganL
Captain Morgan
Administrator
HI !
Clemesis
Best to report your hardware specs... see if there is a local terminal or IPMI port
Clemesis
CPU : AMD 3400g
MB : Asrock 450 pro 4
RAM : 64Go Corsair Vengence
Boot disk : Crucial P5 M.2
PSU : Corsair SFX 450w
2 pools :
4x 4to RAIDZ1
2x500go MIRROR
Thanks for your answer !
Clemesis
Clemesis
I installed Turenas Scale on an old hardware, and I found the settings that I modified.
Its under System Settings -> Advanced -> Allowed IP Addresses
From what I read, every settings should be accessible from the CLI (https://www.truenas.com/docs/scale/scaleclireference/)
But I cant find this particular settings since the menus are not alike...
Is someone knows where I can find the "allowed IP addresses" in the CLI ?
Clemesis
Seems it's under System General... can be viewed with config. > ui_allowlist
I don't see a way to change it there, so you may need to resort to the API:
midclt call system.general.config | jq
From there using midclt call system.general.update...where you would set ui_allowlist to an empty list to allow all IPs.
William Bravin
Hello all
@sretalla Sorry for my ignorance and lack of capabilities.
I too have the same issue
the issue is on a truenas scale installed on a supermicro x10.
I currently moved my server to a location where i can hook up the server to a monitor.
If i understand this correctly I would
  1. power up the server
  2. once the server is up
  3. at the prompt i type "midclt call system.general.config | jq" and press return
  4. then i type "midclt call system.general.update" and press return
thien i should be able to access this server from a browser from any pc
Correct?
Thank you in advance for your assist
William Bravin
Update
Problem solved just by reinstalling truenas
