mmix
- May 5, 2021
I believe this issue is not hardware related, but potentially a bug in web interface
I am using
Steps to reproduce:
1. Create pool and dataset inside (SMB, inherit all)
2. Create user, lets call him john
3. Click on "Edit Permissions" on dataset from #1
4. "Use ACL Manager"
5. It shows basic three owner,group,other permissions. Add the 4th, user:john:rwx, although any permission set is ok
6. Save and close
7. It is no longer possible to use "Edit Permissions" on dataset, it just does nothing.
I think it is definitely related to acl not being default, the getfacl on dataset does return the proper config, which means that ACL manager did its job:
However, if I reset the ACL from terminal using
I would have looked at the logs, but I dont know where the web interface code logs are.
I am using
TrueNAS-SCALE-21.04-ALPHA.1
Steps to reproduce:
6. Save and close
$ getfacl dataset1 # file: dataset1 # owner: root # group: root user::rwx user:john:rwx group::r-x mask::rwx other::r-x
sudo setfacl -b dataset1
, the Edit Permission screen shows up normally. But of course that rescinds everything ACL manager did. I would have looked at the logs, but I dont know where the web interface code logs are.
