huseyinozsut
- Jul 12, 2021
Me and my friend are using three truenas scale servers. One was at my friend's office. It had 12 2TB disks. My preferred zfs setup was 2 Raidz Vdevs with two spares in each. It had 16gb ram (non ecc), intel i5 3570 cpu.
In my home I have 6 4TB disks. My preferred setup is 3 mirrored Vdevs. Again 3570 cpu with 24gb ram.
In my office I have 6 6TB disks. My preferred setup is 3 mirrored Vdevs. With 3550 cpu with 16gb ram.
We are going to change some of the configurations.
First, I don't need two servers anymore. My home server will be enough. In my office my need is minimal. So my plan is to migrate my data at home to 6TB disks. Then combine a server with best parts at hand and use 6tb disks in it and use it at home.
My plan is to use 4tb disks at my friend's system. He allready owns one 4tb disk. We will buy one more. Our plan is to create 4 mirrored vdevs in his system. We will probably increase the ram to 32gb.
On monday X540 10gbit network cards will arrive. In our systems we will start using 10gbit network cards.
Our concern is not using ecc ram. Here is the thing: THEY ARE EXPENSIVE!
Rdimms are very cheap in my country; but udimms are seriously expensive. I can find cheap mainboards that support Udimm; but I could not find a cheap server motherboard that supports Rdimm. Is this that important? Or can you suggest a cheap mainboard that supports rdimm, from same era with i5 3570, have at least two PCI-e 8x (16x is also ok). Form factor is not important for me. I can use any mainboard in my case. So, a non atx is also ok for me. I can print something to mount the card to the case, then cut the back of the case etc...
Second, with 4 mirrored 4tb vdevs, considering that we are not using VMs, will 24gb ram be sufficient? Or should I go with 32gb? With 3 mirrored 6TB vdevs I will go with 32gb. I can't pass 32gb since it is the mainboard's limit in both of the systems.
