Carson
- Mar 19, 2014
I just installed a 4tb WD drive and I can only get freenas to see it as a 3tb. I even bought a new SATA 3 controller card and upgraded my motherboard. But no luck. Does anyone know why the 4tb drive is not recognized correctly?
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E0929210
LU WWN Device Id: 5 0014ee 2b46aba67
Firmware Version: 80.00A80
User Capacity: 3,000,615,492,608 bytes [3.00 TB]
Rotation Rate: 5400 rpm
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Mar 19 18:32:56 2014 MDT
SMART support is: Enabled
