Nughs78
- Jun 4, 2022
I've been running a pool of 12 x 4TB is 2 x 6 disk z2 vdevs. They've been running off 2x Dell perc H310s flashed to IT mode P20.
I recently had a drive fail and figured maybe it's time to start slowly swapping drives (they're getting up there), while at the same time enabling a capacity upgrade as the endstate.
I picked up 2 x WD Red 10TB WD101EFBX drives.
Neither drive connected to either card detects, multiple camcontrol errors, eventually timing out.
Anyone here successfully running WD Red 10TB WD101EFBX on SAS 2008 cards?
If so did you run into any issues? Or require specific configuration changes?
