Slacker ITADM
- Jan 4, 2016
Received this after upgrading to FreeNAS-9.10-RELEASE (2def9c8)
Not sure what its telling me.
Warning: Variable $daily_status_security_
chkmounts_ignore is deprecated, use $security_status_chkmounts_ignore instead.
gandalf.local changes in mounted filesystems:
2c2
< freenas-boot/ROOT/default / zfs rw,noatime,nfsv4acls 0 0
> freenas-boot/ROOT/FreeNAS-d1851bb004ead848f18f828f8fd48bae / zfs rw,noatime,nfsv4acls 0 0
3a4
> linprocfs /compat/linux/proc linprocfs rw 0 0
gandalf.local kernel log messages:
> Copyright (c) 1992-2016 The FreeBSD Project.
> FreeBSD 10.3-RC3 #0 86b9b91(freebsd10): Mon Mar 21 17:43:20 PDT 2016
> root@build.ixsystems.com:/tank/home/nightlies/build-freenas9/_BE/objs/tank/home/nightlies/build-freenas9/_BE/trueos/sys/FreeNAS.amd64 amd64
> FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512
> CPU: Intel(R) Core(TM) i3-4170 CPU @ 3.70GHz (3700.07-MHz K8-class CPU)
> Origin="GenuineIntel" Id=0x306c3 Family=0x6 Model=0x3c Stepping=3
> Features2=0x7fdafbbf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,SDBG,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
> Structured Extended Features=0x27ab<FSGSBASE,TSCADJ,BMI1,AVX2,SMEP,BMI2,ERMS,INVPCID,NFPUSG>
> XSAVE Features=0x1<XSAVEOPT>
> VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID
> avail memory = 16551084032 (15784 MB)
> random: <Software, Yarrow> initialized
> module_register_init: MOD_LOAD (vesa, 0xffffffff80dcd910, 0) error 19
> xhci0: <Intel Lynx Point USB 3.0 controller> mem 0xf7300000-0xf730ffff irq 16 at device 20.0 on pci0
> xhci0: 32 bytes context size, 64-bit DMA
> xhci0: Port routing mask set to 0xffffffff
> usbus0 on xhci0
> ehci0: <Intel Lynx Point USB 2.0 controller USB-B> mem 0xf7314000-0xf73143ff irq 16 at device 26.0 on pci0
> usbus1: EHCI version 1.0
> usbus1 on ehci0
> igb0: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0xd000-0xd01f mem 0xf7200000-0xf727ffff,0xf7280000-0xf7283fff irq 18 at device 0.0 on pci3
> igb1: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0xc000-0xc01f mem 0xf7100000-0xf717ffff,0xf7180000-0xf7183fff irq 19 at device 0.0 on pci4
> ehci1: <Intel Lynx Point USB 2.0 controller USB-A> mem 0xf7313000-0xf73133ff irq 22 at device 29.0 on pci0
> usbus2: EHCI version 1.0
> usbus2 on ehci1
> ichwd0 on isa0
> ichwd0: ICH WDT present but disabled in BIOS or hardware
> device_attach: ichwd0 attach returned 6
> wbwd0: <Nuvoton WPCM450RA0BX> at port 0x2e-0x2f on isa0
> ichwd0 at port 0x1830-0x1837,0x1860-0x187f on isa0
> random: unblocking device.
> usbus0: 5.0Gbps Super Speed USB v3.0
> usbus2: 480Mbps High Speed USB v2.0
> ugen0.1: <0x8086> at usbus0
> uhub0: <0x8086 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
> ugen2.1: <Intel> at usbus2
> uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
> uhub2: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
> uhub2: 2 ports with 2 removable, self powered
> uhub0: 21 ports with 21 removable, self powered
> ugen0.2: <vendor 0x0557> at usbus0
> uhub3: <vendor 0x0557 product 0x7000, class 9/0, rev 1.10/1.00, addr 1> on usbus0
> uhub4: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.05, addr 2> on usbus1
> ugen2.2: <vendor 0x8087> at usbus2
> uhub5: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.05, addr 2> on usbus2
> uhub4: 6 ports with 6 removable, self powered
> uhub5: 6 ports with 6 removable, self powered
> uhub3: 4 ports with 4 removable, self powered
> ugen0.3: <ATEN Advance Tech Inc.> at usbus0
> ukbd0: <ATEN Advance Tech Inc. CS84U-TR, class 0/0, rev 1.10/1.00, addr 2> on usbus0
> ugen0.4: <vendor 0x0557> at usbus0
> uhub6: <vendor 0x0557 product 0x7000, class 9/0, rev 2.00/0.00, addr 3> on usbus0
> uhub6: 4 ports with 3 removable, self powered
> ugen0.5: <vendor 0x0557> at usbus0
> ukbd1: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus0
> ugen0.6: <CPS> at usbus0
> ada0: <WDC WD40EFRX-68WT0N0 82.00A82> ACS-2 ATA SATA 3.x device
> ada0: 3815447MB (7814037168 512 byte sectors)
> ada1: <WDC WD40EFRX-68WT0N0 82.00A82> ACS-2 ATA SATA 3.x device
> ada1: 3815447MB (7814037168 512 byte sectors)
> ada2: <WDC WD40EFRX-68WT0N0 80.00A80> ACS-2 ATA SATA 3.x device
> ada2: 3815447MB (7814037168 512 byte sectors)
> ada3: <WDC WD40EFRX-68WT0N0 80.00A80> ACS-2 ATA SATA 3.x device
> ada3: 3815447MB (7814037168 512 byte sectors)
> ada4: <SanDisk SDSSDA120G Z22000RL> ACS-2 ATA SATA 3.x device
> ada4: 114473MB (234441648 512 byte sectors)
> SMP: AP CPU #3 Launched!
> Timecounter "TSC-low" frequency 1850036724 Hz quality 1000
> Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-d1851bb004ead848f18f828f8fd48bae []...
> igb0: link state changed to UP
> hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> UCP/8/48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI>
> igb0: link state changed to DOWN
> vboxdrv: fAsync=0 offMin=0x33e offMax=0xedc
> GEOM_ELI: Encryption: AES-XTS 128
> pid 1372 (syslog-ng), uid 0: exited on signal 6 (core dumped)
Checking for packages with security vulnerabilities:
-- End of security output --
2c2
3a4
> usbus0 on xhci0
> usbus1 on ehci0
> usbus2 on ehci1
> ichwd0 on isa0
