jbbender22
- Aug 15, 2014
Hi All,
I recently purchased a pair of SK Hynix Gold S31 SSDs to use as a pool dedicated for my jails. Upon receiving them I did SMART tests in another machine without error so I threw them in my system and proceeded to get things set up. While testing my SMART Report email to make sure these drives showed up, I noticed a strange few lines in the output:
My TrueNAS system hasn't thrown any errors at me, which is contrary to what I see when I've been looking this up. A lot of the folks with similar lines in their SMART output were using Crucial MX500 drives with buggy firmware, but most, if not all, were actually getting errors reported emailed to them or within the TrueNAS GUI. The drives have been installed for roughly 18 hours or so.
Is this something I should be concerned about? I'm not totally sure how I should read this.
Here's the full output from one of the drives:
Am I missing something here? Any insight would be greatly appreciated!
SMART Error Log Version: 1 Warning: ATA error count 0 inconsistent with error log pointer 1
SMART Attributes Data Structure revision number: 0 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000e 166 166 006 Old_age Always - 0 5 Reallocated_Sector_Ct 0x0032 100 100 036 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 19 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 3 100 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 168 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 169 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 174 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 175 Program_Fail_Count_Chip 0x0032 100 100 000 Old_age Always - 0 176 Erase_Fail_Count_Chip 0x0032 100 100 000 Old_age Always - 0 177 Wear_Leveling_Count 0x0032 100 100 000 Old_age Always - 0 178 Used_Rsvd_Blk_Cnt_Chip 0x0032 100 100 000 Old_age Always - 0 179 Used_Rsvd_Blk_Cnt_Tot 0x0032 100 100 000 Old_age Always - 0 180 Unused_Rsvd_Blk_Cnt_Tot 0x0032 100 100 000 Old_age Always - 922 184 End-to-End_Error 0x0032 100 100 000 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 194 Temperature_Celsius 0x0022 022 044 000 Old_age Always - 22 (Min/Max 21/44) 195 Hardware_ECC_Recovered 0x000e 100 100 000 Old_age Always - 0 196 Reallocated_Event_Count 0x0032 100 100 036 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0 204 Soft_ECC_Correction 0x000e 100 100 000 Old_age Always - 456508 212 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 14 233 Media_Wearout_Indicator 0x0023 100 100 001 Pre-fail Always - 100 234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 0 242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 0 SMART Error Log Version: 1 Warning: ATA error count 0 inconsistent with error log pointer 1 ATA Error Count: 0 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 3 - # 2 Extended offline Completed without error 00% 1 - SMART Selective self-test log data structure revision number 0 Note: revision number not 1 implies that no selective self-test has ever been run SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
