Do I need SMART for SSD
mike360x1
I just recently got an error from GUI stating that one of my SSDs (/dev/ada3) has failed its self test. This SSD is fairly new (1 month running) and doesn't see a lot of use.
Device: /dev/ada3, FAILED SMART self-check. BACK UP DATA NOW!
So, I know that SMART tests are designed for HDDs and I've heard that there are sometimes software issues because the SMART test wasn't intended for SSD testing.
Does this Critical Message from freenas above mean that the SSD is showing signs of failiure? Or maybe its simply a problem with SMART.
I will also include the results of a SMART report.
########## SMART status report summary for all drives ##########
|Device|Serial         |Temp|Power|Start|Spin |ReAlloc|Current|Offline |UDMA  |Seek  |High  |Command|Last|
|      |               |    |On   |Stop |Retry|Sectors|Pending|Uncorrec|CRC   |Errors|Fly   |Timeout|Test|
|      |               |    |Hours|Count|Count|       |Sectors|Sectors |Errors|      |Writes|Count  |Age |
|ada0 !|WD-WCASZ0981600| 44 |13544| 2479|    0|      0|      0|       0|     0|   N/A|   N/A|    N/A|   3|
|ada1 ?|WD-WCC4N6HJPEA8| 34 | 2133|   35|    0|      0|      0|       0|     0|   N/A|   N/A|    N/A|   3|
|ada2 ?|WD-WCC2EF180508| 40 | 9632| 1997|    0|      0|      0|       0|     0|   N/A|   N/A|    N/A|   3|
|ada3 ?|50026B77620971CB| 32 |1212h+22m+25.100s|     |     |       |       |        |      |   N/A|   N/A|    N/A|   3|
|ada4 ?|WD-WCC6Y5SV5NJ5| 37 | 1842|   28|    0|      0|      0|       0|     0|   N/A|   N/A|    N/A|   3|
|ada5 ?|WD-WCC4N4TLAA6X| 37 | 1842|   28|    0|      0|      0|       0|     0|   N/A|   N/A|    N/A|   3|
|ada6  |CVLT615400EJ240CGN|  |   12|     |     |      0|       |        |     0|   N/A|   N/A|    N/A|   0|
|ada7  |134628400766   |  |     |     |     |       |       |        |      |   N/A|   N/A|    N/A|   0|
########## SMART status report for ada0 drive (Western Digital Caviar: WD-WCASZ0981600) ##########
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   235   157   021    Pre-fail  Always       -       1216
  4 Start_Stop_Count        0x0032   098   098   000    Old_age   Always       -       2479
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   082   082   000    Old_age   Always       -       13544
10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1976
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       430
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       2477
194 Temperature_Celsius     0x0022   103   098   000    Old_age   Always       -       44
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
No Errors Logged
Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
Short offline       Completed without error       00%     13464         -
########## SMART status report for ada1 drive (Western Digital Red: WD-WCC4N6HJPEA8) ##########
  3 Spin_Up_Time            0x0027   179   175   021    Pre-fail  Always       -       6050
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       35
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       2133
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       34
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       13
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       31
194 Temperature_Celsius     0x0022   116   109   000    Old_age   Always       -       34
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
No Errors Logged
Short offline       Completed without error       00%      2053         -
########## SMART status report for ada2 drive (Western Digital Blue: WD-WCC2EF180508) ##########
  3 Spin_Up_Time            0x0027   141   137   021    Pre-fail  Always       -       3908
  4 Start_Stop_Count        0x0032   099   099   000    Old_age   Always       -       1997
  9 Power_On_Hours          0x0032   087   087   000    Old_age   Always       -       9632
12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1634
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       396
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1600
194 Temperature_Celsius     0x0022   103   098   000    Old_age   Always       -       40
No Errors Logged
Short offline       Completed without error       00%      9552         -
########## SMART status report for ada3 drive (SandForce Driven SSDs: 50026B77620971CB) ##########
  1 Raw_Read_Error_Rate     0x0032   120   120   050    Old_age   Always       -       0/0
  5 Retired_Block_Count     0x0033   100   100   003    Pre-fail  Always       -       0
  9 Power_On_Hours_and_Msec 0x0032   099   099   000    Old_age   Always       -       1212h+22m+26.120s
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       23
171 Program_Fail_Count      0x000a   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
174 Unexpect_Power_Loss_Ct  0x0030   000   000   000    Old_age   Offline      -       15
177 Wear_Range_Delta        0x0000   000   000   000    Old_age   Offline      -       0
181 Program_Fail_Count      0x000a   100   100   000    Old_age   Always       -       0
182 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
187 Reported_Uncorrect      0x0012   100   100   000    Old_age   Always       -       0
189 Airflow_Temperature_Cel 0x0000   032   043   000    Old_age   Offline      -       32 (Min/Max 22/43)
194 Temperature_Celsius     0x0022   032   043   000    Old_age   Always       -       32 (Min/Max 22/43)
195 ECC_Uncorr_Error_Count  0x001c   120   120   000    Old_age   Offline      -       0/0
196 Reallocated_Event_Count 0x0033   100   100   003    Pre-fail  Always       -       0
201 Unc_Soft_Read_Err_Rate  0x001c   120   120   000    Old_age   Offline      -       0/0
204 Soft_ECC_Correct_Rate   0x001c   120   120   000    Old_age   Offline      -       0/0
230 Life_Curve_Status       0x0013   100   100   000    Pre-fail  Always       -       100
231 SSD_Life_Left           0x0000   100   100   011    Old_age   Offline      -       42949672960
233 SandForce_Internal      0x0032   000   000   000    Old_age   Always       -       840
234 SandForce_Internal      0x0032   000   000   000    Old_age   Always       -       559
241 Lifetime_Writes_GiB     0x0032   000   000   000    Old_age   Always       -       559
242 Lifetime_Reads_GiB      0x0032   000   000   000    Old_age   Always       -       274
244 Unknown_Attribute       0x0000   100   100   010    Old_age   Offline      -       1048581
SMART Error Log not supported
Short offline       Completed without error       00%      1132         -
########## SMART status report for ada4 drive (Western Digital Blue: WD-WCC6Y5SV5NJ5) ##########
  3 Spin_Up_Time            0x0027   177   174   021    Pre-fail  Always       -       2125
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       28
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       1842
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       27
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       8
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       22
194 Temperature_Celsius     0x0022   106   100   000    Old_age   Always       -       37
No Errors Logged
Short offline       Completed without error       00%      1762         -
########## SMART status report for ada5 drive (Western Digital Red: WD-WCC4N4TLAA6X) ##########
  3 Spin_Up_Time            0x0027   180   178   021    Pre-fail  Always       -       5983
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       26
194 Temperature_Celsius     0x0022   113   108   000    Old_age   Always       -       37
No Errors Logged
########## SMART status report for ada6 drive (: CVLT615400EJ240CGN) ##########
  5 Reallocated_Sector_Ct   0x0032   100   100   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       12
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       17
170 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
171 Unknown_Attribute       0x0032   100   100   010    Old_age   Always       -       0
172 Unknown_Attribute       0x0032   100   100   010    Old_age   Always       -       0
174 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       9
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0033   100   100   090    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0032   037   044   000    Old_age   Always       -       37 (Min/Max 32/44)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       9
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
225 Unknown_SSD_Attribute   0x0032   100   100   000    Old_age   Always       -       11653
226 Unknown_SSD_Attribute   0x0032   100   100   000    Old_age   Always       -       0
227 Unknown_SSD_Attribute   0x0032   100   100   000    Old_age   Always       -       0
228 Power-off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       0
232 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
233 Media_Wearout_Indicator 0x0032   100   100   000    Old_age   Always       -       0
241 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       11653
242 Total_LBAs_Read         0x0032   100   100   000    Old_age   Always       -       3149
249 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       104
252 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
No Errors Logged
Short offline       Completed without error       00%        12         -
########## SMART status report for ada7 drive (SanDisk based SSDs: 134628400766) ##########
SMART Disabled. Use option -s with argument 'on' to enable it.
(override with '-T permissive' option)
Strangely enough, I see that the errors GUI is giving me isn't shown here in the report.
I would be grateful for your response :)
Thank you in advance,
Nick2253
mike360x1
I am running:
ASRock C2550D4I MITX Motherboard
Intel® Quad-Core Avoton C2550 Processor
16GB (8GBx2) ECC Dual Channel Memory
Using onboard Sata Controller
Mirrored ( Intel 540S SSD 120GB + Kingston SSDNow V300 120GB) | RaidZ2 2x3TB WD RED + 1TB WD Blue + 2x 500GB WD Blue
Build: FreeNAS-9.10.1 (d989edd)
My Output:
  pool: Default
state: ONLINE
  scan: scrub repaired 0 in 1h38m with 0 errors on Thu Aug 18 04:38:42 2016
        NAME                                            STATE     READ WRITE CKS        UM
        Default                                         ONLINE       0     0        0
          raidz2-0                                      ONLINE       0     0        0
            gptid/4e930ed4-350e-11e6-95e7-d05099c0e979  ONLINE       0     0        0
            gptid/4f6c8717-350e-11e6-95e7-d05099c0e979  ONLINE       0     0        0
            gptid/501b53d4-350e-11e6-95e7-d05099c0e979  ONLINE       0     0        0
            gptid/50d746c2-350e-11e6-95e7-d05099c0e979  ONLINE       0     0        0
            gptid/518cd33c-350e-11e6-95e7-d05099c0e979  ONLINE       0     0        0
errors: No known data errors
  pool: SuperFast
state: ONLINE
  scan: scrub repaired 0 in 0h3m with 0 errors on Thu Aug 18 03:03:54 2016
        SuperFast                                       ONLINE       0     0        0
          mirror-0                                      ONLINE       0     0        0
            gptid/50d50372-5545-11e6-b583-001b21a69378  ONLINE       0     0        0
            gptid/51101a86-5545-11e6-b583-001b21a69378  ONLINE       0     0        0
  pool: freenas-boot
state: ONLINE
  scan: none requested
        NAME                                          STATE     READ WRITE CKSUM
        freenas-boot                                  ONLINE       0     0     0
          gptid/d3a69e39-553b-11e6-af3d-001b21a69378  ONLINE       0     0     0
For the outputs given above and the starting thread, there doesn't seem to be any indication of a failure. Was my situation just an anomaly? Or does Freenas have problems with the Kingston V300 SSD?
