Want to remove Jail
dasnicholas
How do I remove a Jail from my Pool? I removed it from my Plugins and Jails, but its still in my volume?
Do I "Destroy Dataset" under the "jails" level under "Storage"?
Im afraid it will destroy the volume...
Screenshot
diedrichg
You can select the warden template and delete it without issue. However, as soon as you create a new jail, the template will need to be re-downloaded. If you have a slow connection then this would be undesirable. If bandwidth is not an issue - then destroy away.
dasnicholas
"Destory Dataset" will delete it?
diedrichg
I'm a bit confused though. How have you used 92% of your pool but your datasets show only a few percent used? You need to keep your usage below 80% to maintain performance.
diedrichg
dasnicholas
Im trying to get it below, for some reason the Plex Plugin/jail created itself under the first Pool, and not "PoolNick" which is where all my video media lives
dasnicholas
PS, my whole NAS was a hatchet job I pieced together and self taught with very little higher IT knowledge, im sure theirs plenty of stuff that looks weird : p
Jailer
Not strong, but bad
You better free up some space or expand your pool soon or things are going to go Tango Uniform.
