moosefaceahoy
- Dec 21, 2018
I recently used the migrate_warden.py script to migrate a jail from warden to iocage to see how the script performed. I'd like to remove the iocage jail that was created in the migration, but when I use the 'iocage destroy jail_name' command, I get the following output:
jail_name has dependent jails (who may also have dependents), use --recursive to destroy:
WardenMigration_2018-12-21
If I use the --recursive command, is this only destroying the iocage jail, or will this also destroy the warden jail as well? Using iocage commands, I can't find any reference to WardenMigration_2018-12-21 that is referenced in the command output.
Thank you!
Thank you!
