Wake on LAN
emiliow
Hi everyone,
I've set up a freenas system and i like it.
So var all my plans for using the nas have worked out, i'm pretty much a noob with freenas.
But now i would like to be able to boot my nas with wol.
My networking card supports wol_magic, freenas says so, but it is not working.
I tried enabling wol manually but no luck.
Also i've got a windows xp system drive from which i can boot, when i set up windows xp for wol and then try to boot with wake on lan it does work.
Then when i let the system boot freenas and shut it down wake on lan doesn't work anymore.
The Networking controller is a Marvell 88E1116 Gigabit Ethernet controller integrated on a Gigabyte Ga-M59SLI-S5
Hope somebody can help me out.
Thanks
Have you even searched the forums? I just posted to a wake on lan thread not even 5 hours ago.
Michael Wulff Nielsen
I have been working on this exact same problem. It seems that you should enable it on the network interface before shutdown.
What does "ifconfig -m" give you?
N00b
This is what I get (to compare since WOL works for me at the moment!). I don't remember if I made changes to FreeNAS (inet) or just enabled it in the BIOS.
em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=4219b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,WOL_MAGIC,VLAN_HWTSO>
        capabilities=5399b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO>
        ether XX:XX:XX:XX:XX:XX
        inet 192.168.x.xx netmask 0xffffff00 broadcast 192.168.1.255
        inet 192.168.x.xxx netmask 0xffffff00 broadcast 192.168.1.255
        nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL>
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
        supported media:
                media autoselect
                media 1000baseT
                media 1000baseT mediaopt full-duplex
                media 100baseTX mediaopt full-duplex
                media 100baseTX
                media 10baseT/UTP mediaopt full-duplex
                media 10baseT/UTP
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        capabilities=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
I think you may have set the "WOL_MAGIC" option manually. probably with "ifconfig em0 magic". But what is your nic? My Intel nic does not have the WOL_MAGIC capability.
N00b
Now that you mention it I vaguely remember that I probably did something as the WOL was not working out of the box and I got the same issue as reported by you. But I couldn't be sure. I have an Intel DH55TC desktop board that I am using but it has an Intel NIC. Googling the specs it says it is using the Intel® 82578DC Gigabit Ethernet Controller and dmesg.boot out shows:
"em0: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0xf040-0xf05f mem 0xfe400000-0xfe41ffff,0xfe428000-0xfe428fff irq 20 at device 25.0 on pci0"
Hope that helps.
Actually that helps a lot. Intel shipped a series of server/desktop nics with that chip. The Intel Pro 1000/PT among others ships with this controller chip. I think I will buy one and see if it works with FreeNas.
emiliow
Thanks for the replies.
I can't get to my computer right now but i think i see a difference in the "ifconfig -m" output.
If i remember correctly WOL_MAGIC is listed under "capabilities=" but not under "options=".
So i guess it has to be enabled. I tried this already several ways:
  • I put wol and wol_magic under network->interfaces->options in freenas webgui.
  • Via the shell "ifconfig nfe1 wol wol_magic"
My NIC is a nvidia nForce networking controller.
nfe1: <NVIDIA nForce MCP55 Networking Adapter>
R.G.
I just got my FreeNAS to do a WOL by removing the Intel PRO/1000 GT that I had bought specifically because there were reported problems with the RT8111F that the motherboard uses, and then re-enabling the Realtek.
This really is like a video game - to be successful, you have to have performed/set the right tasks/settings in many apparently unrelated places.
For reference, what is working now is an Asus M5A97 R2.0 with 16G of memory, with wake on PME set and the onboard network interface set enabled in the BIOS.
