Volume Degraded
carleycr
For a few weeks I've had an error saying the volume is degraded. I've done smart tests cleared checksum errors, and scubs with no luck on how to fix the issue. Please help.
nojohnny101
When you performed the smart tests, did it pass long and short?
What is your hardware and software version (required for all posts as per the forum rules)?
zpool status shows the drive is failing but your alerts in the GUI show that diffident identifiers are shown at different points in time. Between warnings, did you move the disks around, reboot the machine, or change cables of any sort?
Please post the full output (in code tags) of "smartctl -a /dev/adap2" of the offending device (if you didn't reboot or change anything since you posted the screenshots, then it would be "adap2" as I indicated above.
carleycr
Yes, both tests passed. Signature updated with specs.
I have not moved any disks around, or change cables. I have rebooted. When I put the smartctl you provided, it says it can't recognize the device type. When I swap out ada5p2 with ada5 I get the attached results.
  • ada5_output.pdf
Why are you attaching a PDF? Post the text in the body of your post, in code tags. Not on pastebin, not with a screenshot, not an attached PDF.
carleycr
Sorry. I have a mac and the forum wouldn't let me post an RTF file. Code below. Software version is 9.10.2-U4
Model Family:	 Western Digital Red
Device Model:	 WDC WD30EFRX-68EUZN0
Serial Number:	WD-WMC4N1339598
LU WWN Device Id: 5 0014ee 65965829b
Firmware Version: 80.00A80
User Capacity:	3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Sat Jul 22 15:24:13 2017 CDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
been run.
data collection: (41640) seconds.
capabilities:  (0x7b) SMART execute Offline immediate.
command.
Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:  (   2) minutes.
Extended self-test routine
recommended polling time:  ( 418) minutes.
Conveyance self-test routine
recommended polling time:  (   5) minutes.
SCT capabilities:		 (0x703d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   196   178   021	Pre-fail  Always	   -	   5191
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   27
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   065   065   000	Old_age   Always	   -	   26143
10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   27
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   12
193 Load_Cycle_Count		0x0032   001   001   000	Old_age   Always	   -	   773818
194 Temperature_Celsius	 0x0022   119   112   000	Old_age   Always	   -	   31
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	 25985		 -
# 2  Short offline	   Completed without error	   00%	 12990		 -
# 3  Extended offline	Completed without error	   00%	 12951		 -
# 4  Short offline	   Completed without error	   00%	 12870		 -
# 5  Short offline	   Completed without error	   00%	 12799		 -
# 6  Short offline	   Completed without error	   00%	 12727		 -
# 7  Short offline	   Completed without error	   00%	 12655		 -
# 8  Extended offline	Completed without error	   00%	 12615		 -
# 9  Short offline	   Completed without error	   00%	 12511		 -
#10  Short offline	   Completed without error	   00%	 12439		 -
#11  Short offline	   Completed without error	   00%	 12367		 -
#12  Short offline	   Completed without error	   00%	 12319		 -
#13  Short offline	   Completed without error	   00%	 12247		 -
#14  Extended offline	Completed without error	   00%	 12207		 -
#15  Short offline	   Completed without error	   00%	 12127		 -
#16  Short offline	   Completed without error	   00%	 12055		 -
#17  Short offline	   Completed without error	   00%	 11983		 -
#18  Short offline	   Completed without error	   00%	 11911		 -
#19  Extended offline	Completed without error	   00%	 11872		 -
#20  Short offline	   Completed without error	   00%	 11792		 -
#21  Short offline	   Completed without error	   00%	 11720		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Well, this drive went over 13,000 hours without a single SMART test. That isn't good--you should have regularly scheduled SMART tests running on all your drives. And though it passed a short test, that doesn't do much. Try running a long test ( smartctl -t long /dev/ada5), and then posting the output again.
carleycr
I ran the long test as recommended. I believe the drive is ok. Results for ada5 below.
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Menlo; color: #000000; background-color: #ffffff} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Menlo; color: #000000; background-color: #ffffff; min-height: 13.0px} span.s1 {font-variant-ligatures: no-common-ligatures}
smartctl -l selftest /dev/ada5
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
# 1  Extended offline	Completed without error	   00%	 26179		 -
# 2  Short offline	   Completed without error	   00%	 25985		 -
# 3  Short offline	   Completed without error	   00%	 12990		 -
# 4  Extended offline	Completed without error	   00%	 12951		 -
# 5  Short offline	   Completed without error	   00%	 12870		 -
# 6  Short offline	   Completed without error	   00%	 12799		 -
# 7  Short offline	   Completed without error	   00%	 12727		 -
# 8  Short offline	   Completed without error	   00%	 12655		 -
# 9  Extended offline	Completed without error	   00%	 12615		 -
#10  Short offline	   Completed without error	   00%	 12511		 -
#11  Short offline	   Completed without error	   00%	 12439		 -
#12  Short offline	   Completed without error	   00%	 12367		 -
#13  Short offline	   Completed without error	   00%	 12319		 -
#14  Short offline	   Completed without error	   00%	 12247		 -
#15  Extended offline	Completed without error	   00%	 12207		 -
#16  Short offline	   Completed without error	   00%	 12127		 -
#17  Short offline	   Completed without error	   00%	 12055		 -
#18  Short offline	   Completed without error	   00%	 11983		 -
#19  Short offline	   Completed without error	   00%	 11911		 -
#20  Extended offline	Completed without error	   00%	 11872		 -
#21  Short offline	   Completed without error	   00%	 11792		 -
You skipped the most useful parts. Show us the output of smartctl -x /dev/whatever
carleycr
Sorry. Here you go.
Local Time is:	Fri Jul 28 17:54:42 2017 CDT
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
was never started.
been run.
command.
power-saving mode.
ID# ATTRIBUTE_NAME		  FLAGS	VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate	 POSR-K   200   200   051	-	0
  3 Spin_Up_Time			POS--K   196   178   021	-	5191
  4 Start_Stop_Count		-O--CK   100   100   000	-	27
  5 Reallocated_Sector_Ct   PO--CK   200   200   140	-	0
  7 Seek_Error_Rate		 -OSR-K   200   200   000	-	0
  9 Power_On_Hours		  -O--CK   064   064   000	-	26289
 10 Spin_Retry_Count		-O--CK   100   253   000	-	0
 11 Calibration_Retry_Count -O--CK   100   253   000	-	0
 12 Power_Cycle_Count	   -O--CK   100   100   000	-	27
192 Power-Off_Retract_Count -O--CK   200   200   000	-	12
193 Load_Cycle_Count		-O--CK   001   001   000	-	773818
194 Temperature_Celsius	 -O---K   118   112   000	-	32
196 Reallocated_Event_Count -O--CK   200   200   000	-	0
197 Current_Pending_Sector  -O--CK   200   200   000	-	0
198 Offline_Uncorrectable   ----CK   100   253   000	-	0
199 UDMA_CRC_Error_Count	-O--CK   200   200   000	-	0
200 Multi_Zone_Error_Rate   ---R--   200   200   000	-	0
							||||||_ K auto-keep
							|||||__ C event count
							||||___ R error rate
							|||____ S speed/performance
							||_____ O updated online
							|______ P prefailure warning
General Purpose Log Directory Version 1
SMART		   Log Directory Version 1 [multi-sector log support]
Address	Access  R/W   Size  Description
0x00	   GPL,SL  R/O	  1  Log Directory
0x01		   SL  R/O	  1  Summary SMART error log
0x02		   SL  R/O	  5  Comprehensive SMART error log
0x03	   GPL	 R/O	  6  Ext. Comprehensive SMART error log
0x06		   SL  R/O	  1  SMART self-test log
0x07	   GPL	 R/O	  1  Extended self-test log
0x09		   SL  R/W	  1  Selective self-test log
0x10	   GPL	 R/O	  1  SATA NCQ Queued Error log
0x11	   GPL	 R/O	  1  SATA Phy Event Counters log
0x21	   GPL	 R/O	  1  Write stream error log
0x22	   GPL	 R/O	  1  Read stream error log
0x80-0x9f  GPL,SL  R/W	 16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS	  16  Device vendor specific log
0xa8-0xb7  GPL,SL  VS	   1  Device vendor specific log
0xbd	   GPL,SL  VS	   1  Device vendor specific log
0xc0	   GPL,SL  VS	   1  Device vendor specific log
0xc1	   GPL	 VS	  93  Device vendor specific log
0xe0	   GPL,SL  R/W	  1  SCT Command/Status
0xe1	   GPL,SL  R/W	  1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
SCT Status Version:				  3
SCT Version (vendor specific):	   258 (0x0102)
SCT Support Level:				   1
Device State:						Active (0)
Current Temperature:					32 Celsius
Power Cycle Min/Max Temperature:	 27/35 Celsius
Lifetime	Min/Max Temperature:	 18/38 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:	 2
Temperature Sampling Period:		 1 minute
Temperature Logging Interval:		1 minute
Min/Max recommended Temperature:	  0/60 Celsius
Min/Max Temperature Limit:		   -41/85 Celsius
Temperature History Size (Index):	478 (57)
Index	Estimated Time   Temperature Celsius
  58	2017-07-28 09:57	32  *************
 ...	..(242 skipped).	..  *************
 301	2017-07-28 14:00	32  *************
 302	2017-07-28 14:01	30  ***********
 ...	..( 62 skipped).	..  ***********
 365	2017-07-28 15:04	30  ***********
 366	2017-07-28 15:05	31  ************
 367	2017-07-28 15:06	30  ***********
 ...	..(  4 skipped).	..  ***********
 372	2017-07-28 15:11	30  ***********
 373	2017-07-28 15:12	31  ************
 374	2017-07-28 15:13	30  ***********
 ...	..( 10 skipped).	..  ***********
 385	2017-07-28 15:24	30  ***********
 386	2017-07-28 15:25	31  ************
 387	2017-07-28 15:26	30  ***********
 ...	..( 12 skipped).	..  ***********
 400	2017-07-28 15:39	30  ***********
 401	2017-07-28 15:40	31  ************
 402	2017-07-28 15:41	30  ***********
 ...	..(  2 skipped).	..  ***********
 405	2017-07-28 15:44	30  ***********
 406	2017-07-28 15:45	31  ************
 407	2017-07-28 15:46	30  ***********
 ...	..(  7 skipped).	..  ***********
 415	2017-07-28 15:54	30  ***********
 416	2017-07-28 15:55	31  ************
 417	2017-07-28 15:56	30  ***********
 420	2017-07-28 15:59	30  ***********
 421	2017-07-28 16:00	31  ************
 422	2017-07-28 16:01	30  ***********
 427	2017-07-28 16:06	30  ***********
 428	2017-07-28 16:07	31  ************
 429	2017-07-28 16:08	30  ***********
 430	2017-07-28 16:09	30  ***********
 431	2017-07-28 16:10	31  ************
 ...	..( 34 skipped).	..  ************
 466	2017-07-28 16:45	31  ************
 467	2017-07-28 16:46	32  *************
 ...	..( 67 skipped).	..  *************
  57	2017-07-28 17:54	32  *************
SCT Error Recovery Control:
		  Read:	 70 (7.0 seconds)
		  Write:	 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID	  Size	 Value  Description
0x0001  2			0  Command failed due to ICRC error
0x0002  2			0  R_ERR response for data FIS
0x0003  2			0  R_ERR response for device-to-host data FIS
0x0004  2			0  R_ERR response for host-to-device data FIS
0x0005  2			0  R_ERR response for non-data FIS
0x0006  2			0  R_ERR response for device-to-host non-data FIS
0x0007  2			0  R_ERR response for host-to-device non-data FIS
0x0008  2			0  Device-to-host non-data FIS retries
0x0009  2			9  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2			9  Device-to-host register FISes sent due to a COMRESET
0x000b  2			0  CRC errors within host-to-device FIS
0x000f  2			0  R_ERR response for host-to-device data FIS, CRC
0x0012  2			0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4	  4907646  Vendor specific
carleycr
Bump
That drive looks good. Investigate cabling and related issues.
carleycr
I thoroughly cleaned server, reset all sata and power cables, and reset usb drive. No longer getting volume error. Now I'm getting different errors related to SMART tests. Any idea?
carleycr
ada2
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Menlo; color: #000000; background-color: #ffffff} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Menlo; color: #000000; background-color: #ffffff; min-height: 13.0px} span.s1 {font-variant-ligatures: no-common-ligatures} span.Apple-tab-span {white-space:pre}
Serial Number:	WD-WMC4N2936960
LU WWN Device Id: 5 0014ee 059292997
Local Time is:	Sun Aug  6 18:35:35 2017 CDT
was never started.
been run.
data collection: (38940) seconds.
command.
power-saving mode.
recommended polling time:  ( 391) minutes.
  3 Spin_Up_Time			0x0027   179   179   021	Pre-fail  Always	   -	   6016
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   31
  9 Power_On_Hours		  0x0032   064   064   000	Old_age   Always	   -	   26470
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   30
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   16
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   436
194 Temperature_Celsius	 0x0022   121   110   000	Old_age   Always	   -	   29
No Errors Logged
# 1  Short offline	   Completed without error	   00%	 26368		 -
# 2  Short offline	   Completed without error	   00%	 26320		 -
# 3  Short offline	   Completed without error	   00%	 25985		 -
# 4  Short offline	   Completed without error	   00%	 12990		 -
# 5  Extended offline	Completed without error	   00%	 12950		 -
# 6  Short offline	   Completed without error	   00%	 12871		 -
# 7  Short offline	   Completed without error	   00%	 12799		 -
# 8  Short offline	   Completed without error	   00%	 12727		 -
# 9  Short offline	   Completed without error	   00%	 12655		 -
#10  Extended offline	Completed without error	   00%	 12614		 -
#11  Short offline	   Completed without error	   00%	 12511		 -
#12  Short offline	   Completed without error	   00%	 12439		 -
#13  Short offline	   Completed without error	   00%	 12367		 -
#14  Short offline	   Completed without error	   00%	 12319		 -
#15  Short offline	   Completed without error	   00%	 12247		 -
#16  Extended offline	Completed without error	   00%	 12207		 -
#17  Short offline	   Completed without error	   00%	 12127		 -
#18  Short offline	   Completed without error	   00%	 12055		 -
#19  Short offline	   Completed without error	   00%	 11983		 -
#20  Short offline	   Completed without error	   00%	 11912		 -
#21  Extended offline	Completed without error	   00%	 11871		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
ada4
Serial Number:	WD-WMC4N1513863
LU WWN Device Id: 5 0014ee 6aebb1fb3
Local Time is:	Sun Aug  6 18:37:29 2017 CDT
was never started.
been run.
data collection: (41160) seconds.
command.
power-saving mode.
recommended polling time:  ( 413) minutes.
  3 Spin_Up_Time			0x0027   178   178   021	Pre-fail  Always	   -	   6066
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   29
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   28
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   14
193 Load_Cycle_Count		0x0032   001   001   000	Old_age   Always	   -	   824722
No Errors Logged
# 1  Short offline	   Completed without error	   00%	 26369		 -
# 3  Short offline	   Completed without error	   00%	 25984		 -
# 6  Short offline	   Completed without error	   00%	 12870		 -
# 7  Short offline	   Completed without error	   00%	 12798		 -
# 8  Short offline	   Completed without error	   00%	 12726		 -
#10  Extended offline	Completed without error	   00%	 12615		 -
#20  Short offline	   Completed without error	   00%	 11911		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
ada5
Local Time is:	Sun Aug  6 18:38:25 2017 CDT
was never started.
been run.
command.
power-saving mode.
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   28
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   13
193 Load_Cycle_Count		0x0032   001   001   000	Old_age   Always	   -	   777452
No Errors Logged
# 3  Extended offline	Completed without error	   00%	 26179		 -
# 4  Short offline	   Completed without error	   00%	 25985		 -
# 5  Short offline	   Completed without error	   00%	 12990		 -
# 6  Extended offline	Completed without error	   00%	 12951		 -
# 7  Short offline	   Completed without error	   00%	 12870		 -
# 8  Short offline	   Completed without error	   00%	 12799		 -
# 9  Short offline	   Completed without error	   00%	 12727		 -
#10  Short offline	   Completed without error	   00%	 12655		 -
#11  Extended offline	Completed without error	   00%	 12615		 -
#12  Short offline	   Completed without error	   00%	 12511		 -
#13  Short offline	   Completed without error	   00%	 12439		 -
#14  Short offline	   Completed without error	   00%	 12367		 -
#15  Short offline	   Completed without error	   00%	 12319		 -
#16  Short offline	   Completed without error	   00%	 12247		 -
#17  Extended offline	Completed without error	   00%	 12207		 -
#18  Short offline	   Completed without error	   00%	 12127		 -
#19  Short offline	   Completed without error	   00%	 12055		 -
#20  Short offline	   Completed without error	   00%	 11983		 -
#21  Short offline	   Completed without error	   00%	 11911		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Hmmm. Nothing looks especially problematic there, other than the load cycle counts on ada4 and ada5 are awfully high. I'd probably just clear the errors and see if they come back.
carleycr
1 error came back. Is this just FreeNAS not able to write to a specific location? How do I stop these errors?
"CRITICAL: Aug. 21, 2017, 1:23 p.m. - Device: /dev/ada4, Read SMART Error Log Failed"
Redcoat
Are ada2, 4 and 5 on the Intel SATA ports or the Marvell? There's some history of issues with the Marvell ports.
Search here on the forums and you'll find background information relating to the 2750 and 2550 Asrock boards. Here's one example.
