VM has no ethernet
NinthWave
It's been a while since I created a VM and I lost all knowledge.
I created a VM using Proxmox Backup Server ISO installer.
My VM has no access to LAN.. What did I forget ?
NinthWave
Please, surely someone must know why the host does not pass connectivity to the VM
I can provide logs... Simply tell me which are required.
NinthWave
root@truenas[~]# ifconfig -a
bce0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=c00b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
        ether 84:2b:2b:51:53:8a
        inet 10.0.0.6 netmask 0xffffff00 broadcast 10.0.0.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
bce1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=800b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,LINKSTATE>
        ether 84:2b:2b:51:53:8c
        status: active
        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
        groups: lo
pflog0: flags=0<> metric 0 mtu 33160
        groups: pflog
vlan10: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: IOT
        options=80000<LINKSTATE>
        groups: vlan
        vlan: 10 vlanproto: 802.1q vlanpcp: 0 parent interface: bce1
        status: active
vlan40: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: Surveillance
        groups: vlan
        vlan: 40 vlanproto: 802.1q vlanpcp: 0 parent interface: bce1
        status: active
bridge10: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 58:9c:fc:10:e5:2a
        inet 10.0.10.2 netmask 0xffffff00 broadcast 10.0.10.255
        member: vlan10 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 5 priority 128 path cost 55
        groups: bridge
bridge40: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 58:9c:fc:10:ab:7c
        member: vlan40 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 6 priority 128 path cost 55
        groups: bridge
        ether 58:9c:fc:10:54:42
        member: vnet6 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 11 priority 128 path cost 2000000
        member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 10 priority 128 path cost 2000
        member: bce0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 1 priority 128 path cost 20000
        groups: bridge
vnet0.1: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: seafile-jail as nic: epair0b
        options=8<VLAN_MTU>
        ether 86:2b:2b:23:46:0e
        hwaddr 02:81:fb:19:17:0a
        groups: epair
        status: active
vnet6: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether fe:a0:98:2b:af:ce
        hwaddr 58:9c:fc:10:08:26
        groups: tap
        status: active
        Opened by PID 25812
NinthWave
In the ifconfig , I can see bridge0
I dont see it in the GUI. Would not I be able to select bridge0 as "Nic to attach" when creating the VM
Patrick M. Hausen
From your ifconfig output it looks like everything is connected correctly. How is the network configured inside the VM guest OS?
Patrick M. Hausen
That's another minor problem, but that can be addressed later. You should not rely on TrueNAS auto creating the bridge0 for you but instead configure it statically and - most important - remove the IP address from bce0 and put it on the bridge interface instead. But let's get this VM online, first.
An educated guess: you installed from an ISO, so you had a virtual CD-ROM device, correct? And you removed that device completely after you were done? Frequently at least for the Ubuntu releases that I installed that means than inside the guest OS the network interface is renamed from enp0s5 to enp0s4. So the guest does not bring it up anymore because it tries to configure enp0s5 which isn't there.
Search for how you can examine and possibly change the network configuration for Proxmox on the console.
NinthWave
The ifconfig is is the first original post
Here is another output
NinthWave
I think you nailed it.... Trying to edit /etc/network/interfaces
Patrick M. Hausen
Yeah - the configuration file references enp0s5, but from your ifconfig output you can see that the interface is enp0s4. You need to edit the configuration file from the console, change "5" to "4", save and reboot. As I guessed ...
NinthWave
Patrick M. Hausen
So now 10.0.0.17 is reachable? Should be ...
NinthWave
Thanks!!!
I'd like to solve this as well
[edit]
Won't I be losing access to the GUI while doing so, locking me out ^
I am leaving for work but will come back at it tonight
Patrick M. Hausen
1. Shut down your VM and your jail.
2. Set "autostart" to off for both.
3. Reboot your system - this is necessary to remove the auto created bridge0 interface.
4. Create a bridge interface, name it bridge0, assign bce0 as a member interface, test & save.
5. Remove the IP address from bce0, tick the box "disable hardware offloading", put "up" in the "Options" field.
6. Place the IP address on the bridge0 interface.
7. Test & save - possibly increase the test timeout from 60 seconds to 300 or so, might take a while until you can reach your NAS again after clicking "Test".
8. When that works in your VM assign bridge0 to the virtual ethernet device.
9. In your jail set "vnet_default_interfaces" to "none", and down in the network properties section "interfaces" to "vnet0:bridge0"
NinthWave
I realized that since my other VMs and jails are connected to bce1, I would rather put PBS in bce1.
I tried creating a "bridge1" to "bce1" but TN said "bce1" was busy with "vlan40" so I remenbered (I guess) that once a NIC is bridged to vlans, they all must be VLANs. Si I created vlan1, which is fact does not exist. I thought I could put this VM on native LAN (on which is bce0)
This is what I have done but I can't reach the PBS GUI so I guess there is something I did not get right (again) in L2 management.
        status: active
        status: active
        groups: lo
        groups: pflog
        description: IOT
        groups: vlan
        status: active
        groups: vlan
        status: active
        groups: bridge
        groups: bridge
        groups: bridge
        options=8<VLAN_MTU>
        groups: epair
        status: active
vlan1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        groups: vlan
        vlan: 1 vlanproto: 802.1q vlanpcp: 0 parent interface: bce1
        status: active
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 58:9c:fc:10:9f:36
        member: vnet0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 13 priority 128 path cost 2000000
        member: vlan1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
        groups: bridge
vnet0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether fe:a0:98:2b:62:31
        groups: tap
        status: active
        Opened by PID 3164
NinthWave
@Patrick M. Hausen
I connected the VM to "bce1" and it's working but since you suggested in post #6 that I create a static bridge0, I tough I'd do the same for "bce1".... But...
Patrick M. Hausen
Depends. If you need an IP address for your NAS host in that network, then you must statically create the bridge and assign the IP address to the bridge interface. A bridge member interface must not have an IP address.
Static bridges also eliminate the danger of the "bridge creation magic" guessing wrong and creating a loop, specifically with complex topologies with VLANs like yours.
NinthWave
If I understood correctly when you helped me for a similar problem in 2022:
The PBS is a VM on TN-core host and the GUI of PBS is accessible through "bce1"
The data that will be back-up will be exchanged trough "bce0" of TN-core host
If I want PBS to communicate with TN-core NFS share without the need of pfSense firewall (talk directly), then the bridge require an IP address?
But TN refuses I add an IP=10.0.0.5 at bridge1
TN refuses I create bridge1 with bce1 as a member
So I am confused... again
