root@truenas[~]# ifconfig -a
bce0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c00b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether 84:2b:2b:51:53:8a
inet 10.0.0.6 netmask 0xffffff00 broadcast 10.0.0.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
bce1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=800b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,LINKSTATE>
ether 84:2b:2b:51:53:8c
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
vlan10: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: IOT
options=80000<LINKSTATE>
groups: vlan
vlan: 10 vlanproto: 802.1q vlanpcp: 0 parent interface: bce1
status: active
vlan40: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: Surveillance
groups: vlan
vlan: 40 vlanproto: 802.1q vlanpcp: 0 parent interface: bce1
status: active
bridge10: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 58:9c:fc:10:e5:2a
inet 10.0.10.2 netmask 0xffffff00 broadcast 10.0.10.255
member: vlan10 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 55
groups: bridge
bridge40: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 58:9c:fc:10:ab:7c
member: vlan40 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 55
groups: bridge
ether 58:9c:fc:10:54:42
member: vnet6 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 11 priority 128 path cost 2000000
member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
member: bce0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
groups: bridge
vnet0.1: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: seafile-jail as nic: epair0b
options=8<VLAN_MTU>
ether 86:2b:2b:23:46:0e
hwaddr 02:81:fb:19:17:0a
groups: epair
status: active
vnet6: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether fe:a0:98:2b:af:ce
hwaddr 58:9c:fc:10:08:26
groups: tap
status: active
Opened by PID 25812That's another minor problem, but that can be addressed later. You should not rely on TrueNAS auto creating the bridge0 for you but instead configure it statically and - most important - remove the IP address from bce0 and put it on the bridge interface instead. But let's get this VM online, first.In the ifconfig , I can seebridge0
I dont see it in the GUI. Would not I be able to selectbridge0as "Nic to attach" when creating the VM
The ifconfig is is the first original postFrom your ifconfig output it looks like everything is connected correctly. How is the network configured inside the VM guest OS?
I think you nailed it.... Trying to edit /etc/network/interfacesThat's another minor problem, but that can be addressed later. You should not rely on TrueNAS auto creating the bridge0 for you but instead configure it statically and - most important - remove the IP address from bce0 and put it on the bridge interface instead. But let's get this VM online, first.
An educated guess: you installed from an ISO, so you had a virtual CD-ROM device, correct? And you removed that device completely after you were done? Frequently at least for the Ubuntu releases that I installed that means than inside the guest OS the network interface is renamed from enp0s5 to enp0s4. So the guest does not bring it up anymore because it tries to configure enp0s5 which isn't there.
Search for how you can examine and possibly change the network configuration for Proxmox on the console.
Thanks!!!That's another minor problem, but that can be addressed later. You should not rely on TrueNAS auto creating the bridge0 for you but instead configure it statically and - most important - remove the IP address from bce0 and put it on the bridge interface instead. But let's get this VM online, first.
I realized that since my other VMs and jails are connected to bce1, I would rather put PBS in bce1.1. Shut down your VM and your jail.
2. Set "autostart" to off for both.
3. Reboot your system - this is necessary to remove the auto created bridge0 interface.
4. Create a bridge interface, name it bridge0, assign bce0 as a member interface, test & save.
5. Remove the IP address from bce0, tick the box "disable hardware offloading", put "up" in the "Options" field.
6. Place the IP address on the bridge0 interface.
7. Test & save - possibly increase the test timeout from 60 seconds to 300 or so, might take a while until you can reach your NAS again after clicking "Test".
8. When that works in your VM assign bridge0 to the virtual ethernet device.
9. In your jail set "vnet_default_interfaces" to "none", and down in the network properties section "interfaces" to "vnet0:bridge0"
status: active
status: active
groups: lo
groups: pflog
description: IOT
groups: vlan
status: active
groups: vlan
status: active
groups: bridge
groups: bridge
groups: bridge
options=8<VLAN_MTU>
groups: epair
status: active
vlan1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
groups: vlan
vlan: 1 vlanproto: 802.1q vlanpcp: 0 parent interface: bce1
status: active
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 58:9c:fc:10:9f:36
member: vnet0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 13 priority 128 path cost 2000000
member: vlan1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
groups: bridge
vnet0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether fe:a0:98:2b:62:31
groups: tap
status: active
Opened by PID 3164If I understood correctly when you helped me for a similar problem in 2022:Depends. If you need an IP address for your NAS host in that network, then you must statically create the bridge and assign the IP address to the bridge interface. A bridge member interface must not have an IP address.
