rschneider82
 - Oct 4, 2023
I am trying to set up a VM for PLEX with GPU passthought and when I create the VM I get a display error. I have tried it with 2 different GPU Cards. Nivida Quadro P400 and Quadro P2000.
Running
Dell Poweredge R510
2x Intel(R) Xeon(R) CPU E5620 @ 2.40GHz
RAM 23.5GiB ECC
TrueNAS-SCALE-22.12.4
VM Setup
Here is the error Message
			Running
Dell Poweredge R510
RAM 23.5GiB ECC
admin@truenas[~]$ lspci |grep NVIDIA
04:00.0 VGA compatible controller: NVIDIA Corporation GP106GL [Quadro P2000] (rev a1)
04:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1)
05:00.0 VGA compatible controller: NVIDIA Corporation GP107GL [Quadro P400] (rev a1)
05:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
VM Setup
Virtual CPUs:
Cores:
4
Threads:
Memory Size:
8.00 GiB
Boot Loader Type:
UEFI_CSM
System Clock:
LOCAL
Display Port:
5900
Description:
N/A
Shutdown Timeout:
90 seconds
CallError
[EFAULT] internal error: process exited while connecting to monitor: 2023-10-04T13:37:01.950305Z qemu-system-x86_64: -device vfio-pci,host=0000:05:00.0,id=hostdev0,bus=pci.0,addr=0x8: vfio 0000:05:00.0: failed to setup container for group 15: Failed to set iommu for container: Operation not permitted
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 172, in start
if self.domain.create() < 0:
File "/usr/lib/python3/dist-packages/libvirt.py", line 1353, in create
raise libvirtError('virDomainCreate() failed')
libvirt.libvirtError: internal error: process exited while connecting to monitor: 2023-10-04T13:37:01.950305Z qemu-system-x86_64: -device vfio-pci,host=0000:05:00.0,id=hostdev0,bus=pci.0,addr=0x8: vfio 0000:05:00.0: failed to setup container for group 15: Failed to set iommu for container: Operation not permitted
Code:Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 184, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1317, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1379, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1247, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 46, in start await self.middleware.run_in_thread(self._start, vm['name']) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1234, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1231, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 68, in _start self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name)) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 181, in start raise CallError('\n'.join(errors)) middlewared.service_exception.CallError: [EFAULT] internal error: process exited while connecting to monitor: 2023-10-04T13:37:01.950305Z qemu-system-x86_64: -device vfio-pci,host=0000:05:00.0,id=hostdev0,bus=pci.0,addr=0x8: vfio 0000:05:00.0: failed to setup container for group 15: Failed to set iommu for container: Operation not permitted
