VLC (UPNP Not Working) - Win 7 x64 / MiniDLNA 1.0.25 - FN 9.1 Release
Yatti420
Hello again everybody..
Does anybody else have problems with viewing upnp via VLC with Windows 7 machines? I can see my server aswell with foobar.. Foobar works no problems for viewing directories etc.. VLC shows the server and lets me click to look for directories but finds nothing .. Foobar with UPNP added works fine songs play etc.. Any advice would be great..
Thanks,
Yatti420
Seems to be an issue with either the way I setup VLC or Windows/Ubuntu or network as VLC just wont display shares via upnp..
survive
Behold the Wumpus
Hi Yatti420,
Might be a dumb question, but why on earth are you trying to stream to VLC? Why don't you make your media files available on a share and play them with VLC instead?
-Will
Yatti420
Hi Will,
I have CIFS / NFS and SSH on.. I also use MiniDLNA (with UPNP disabled on the router & all upnp servers disabled on PCs) and Transmission.. XBMC works on my ubuntu PC for NFS/CIFS however VLC doesn't work for NFS UPNP..
I think there should be a big red flag for MiniDLNA and UPNP considering how many routers have UPNP on the WAN port.. Just catching up security wise..
https://www.grc.com/x/ne.dll?bh0bkyd2 (ShieldsUP/UPNP exposure test)..
https://media.grc.com/sn/sn-389.mp3 SN-389 (Listener Feedback 141 & UPNP Exposure Disaster)
Basically I just want the flexibility to use any protocol I want.. Preferrably NFS or UPNP with Ubuntu etc..
Yatti420
VLC get's this far.. Looks like it's not seeing MiniDLNA index?
upnp debug: Adding server 'NAS-MiniDLNA' with uuid 'uuid:4d696e69-444c-164e-9d41-0227eb00090b'
main debug: Adding NAS-MiniDLNA in (null)
main debug: rebuilding array of current - root Playlist
main debug: rebuild done - 0 items, index -1
main debug: Creating an input for 'NAS-MiniDLNA'
main debug: no fetch required for (null) (art currently (null))
main debug: processing request item:NAS-MiniDLNA, node: Universal Plug'n'Play, skip: 0
main debug: rebuilding array of current - root Universal Plug'n'Play
main debug: rebuild done - 1 items, index 0
main debug: starting playback of the new playlist item
main debug: resyncing on NAS-MiniDLNA
main debug: NAS-MiniDLNA is at 0
main debug: creating new input thread
main debug: Creating an input for 'JS-MiniDLNA'
main debug: using timeshift granularity of 50 MiB, in path 'C:\Users\Jd\AppData\Local\Temp'
main debug: `vlc://nop' gives access `vlc' demux `' path `nop'
main debug: creating demux: access='vlc' demux='' location='nop' file='\\nop'
main debug: looking for access_demux module: 1 candidate
idummy info: command `nop'
main debug: using access_demux module "idummy"
main debug: TIMER module_need() : 37.642 ms - Total 37.642 ms / 1 intvls (Avg 37.642 ms)
main debug: looking for meta reader module: 2 candidates
lua debug: Trying Lua scripts in C:\Users\\AppData\Roaming\vlc\lua\meta\reader
lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\reader
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\reader\filename.luac
main debug: no meta reader module matching "any" could be loaded
main debug: TIMER module_need() : 9.082 ms - Total 9.082 ms / 1 intvls (Avg 9.082 ms)
main debug: `vlc://nop' successfully opened
main debug: EOF reached
main debug: removing module "idummy"
main debug: dead input
main debug: TIMER input launching for 'AS-MiniDLNA' : 59.150 ms - Total 59.150 ms / 1 intvls (Avg 59.150 ms)
main debug: changing item without a request (current 0/1)
main debug: nothing to play
main debug: processing request item: dNAS-MiniDLNA, node: Universal Plug'n'Play, skip: 0
main debug: resyncing on AS-MiniDLNA
main debug: -MiniDLNA is at 0
main debug: resyncing on JNAS-MiniDLNA
main debug: Creating an input for 'AS-MiniDLNA'
main debug: using timeshift granularity of 50 MiB, in path 'C:\Users\\AppData\Local\Temp'
main debug: TIMER module_need() : 0.503 ms - Total 0.503 ms / 1 intvls (Avg 0.503 ms)
main debug: TIMER module_need() : 3.948 ms - Total 3.948 ms / 1 intvls (Avg 3.948 ms)
main debug: finished input
main debug: TIMER input launching for 'JdNAS-MiniDLNA' : 11.671 ms - Total 11.671 ms / 1 intvls (Avg 11.671 ms)
main debug: processing request item:dNAS-MiniDLNA, node: Universal Plug'n'Play, skip: 0
main debug: Creating an input fNAS-MiniDLNA'
main debug: using timeshift granularity of 50 MiB, in path 'C:\Users\AppData\Local\Temp'
main debug: TIMER module_need() : 0.677 ms - Total 0.677 ms / 1 intvls (Avg 0.677 ms)
lua debug: Trying Lua scripts in C:\Users\AppData\Roaming\vlc\lua\meta\reader
main debug: TIMER module_need() : 5.687 ms - Total 5.687 ms / 1 intvls (Avg 5.687 ms)
main debug: TIMER input launching for 'NAS-MiniDLNA' : 9.000 ms - Total 9.000 ms / 1 intvls (Avg 9.000 ms)
-- MiniDLNA 1.1.0 (Manual) Test/Upgrade Thread http://forums.freenas.org/threads/upgrading-testing-readymedia-minidlna-1-1-0.15110/ --
Yatti420
main debug: processing request item: test110standalone, node: Universal Plug'n'Play, skip: 0
main debug: resyncing on test110standalone
main debug: test110standalone is at 0
main debug: Creating an input for 'test110standalone'
main debug: TIMER module_need() : 0.529 ms - Total 0.529 ms / 1 intvls (Avg 0.529 ms)
main debug: TIMER module_need() : 4.027 ms - Total 4.027 ms / 1 intvls (Avg 4.027 ms)
main debug: TIMER input launching for 'test110standalone' : 7.641 ms - Total 7.641 ms / 1 intvls (Avg 7.641 ms)
main debug: TIMER module_need() : 0.723 ms - Total 0.723 ms / 1 intvls (Avg 0.723 ms)
main debug: TIMER module_need() : 9.011 ms - Total 9.011 ms / 1 intvls (Avg 9.011 ms)
main debug: TIMER input launching for 'test110standalone' : 12.435 ms - Total 12.435 ms / 1 intvls (Avg 12.435 ms)
main debug: TIMER module_need() : 2.748 ms - Total 2.748 ms / 1 intvls (Avg 2.748 ms)
main debug: TIMER module_need() : 4.550 ms - Total 4.550 ms / 1 intvls (Avg 4.550 ms)
main debug: TIMER input launching for 'test110standalone' : 11.284 ms - Total 11.284 ms / 1 intvls (Avg 11.284 ms)
main debug: TIMER module_need() : 0.955 ms - Total 0.955 ms / 1 intvls (Avg 0.955 ms)
main debug: TIMER module_need() : 4.104 ms - Total 4.104 ms / 1 intvls (Avg 4.104 ms)
main debug: TIMER input launching for 'test110standalone' : 7.541 ms - Total 7.541 ms / 1 intvls (Avg 7.541 ms)
main debug: TIMER module_need() : 0.772 ms - Total 0.772 ms / 1 intvls (Avg 0.772 ms)
main debug: TIMER module_need() : 5.555 ms - Total 5.555 ms / 1 intvls (Avg 5.555 ms)
main debug: TIMER input launching for 'test110standalone' : 9.396 ms - Total 9.396 ms / 1 intvls (Avg 9.396 ms)
upnp error: Unknown error code when trying the send() action with URL: http://192.168.0.127:8200/ctl/ContentDir
upnp error: No response from browse() action
qt4 debug: Using an item specific info windows
main debug: looking for services probe module: 6 candidates
main debug: no services probe module matching "any" could be loaded
main debug: TIMER module_need() : 18.519 ms - Total 18.519 ms / 1 intvls (Avg 18.519 ms)
qt4 debug: Sorting by column -1, order 0
qt4 debug: Normal PL/ML or SD
mfcexpert
mfcexpert
I can't help with your problem except to say that it happens with Windows 8 connected to uPnP running under XBMC on a Raspberry Pi under Debian. Windows media player works just fine but VLC will only play the files under Samba.
Yatti420
I should clarify my configuration..
DIR-655 (UPNP Disabled - FW2.11 with UPNP fixes)
wired xbox/wireless pc clients (win/ubuntu)
wired PS3
Windows clients upnp services disabled.. WMP will not work for me without these..
So just to confirm you attempted to use VLC within Windows 8 and no shares either?
On XBMC/MiniDLNA with pictures loaded can you confirm pictures are displaying on xbmc? I'm having issues on my original xbox with MiniDLNA even showing up now.. Will have to look at that later..
I think there is an issue with UPNP-Pictures on all XBMC (atleast that I use xbox/ubuntu/windows gotham alpha wont work/display image) See http://forums.freenas.org/threads/u...ymedia-minidlna-1-1-0.15110/page-2#post-76458
mfcexpert
wired PS3
mfcexpert
[So just to confirm you attempted to use VLC within Windows 8 and no shares either?/QUOTE]
I'll try to remember as best I can (the SD card on the Pi broke).
First of all I'm not running Freenas so I think the problem is with VLC.
I had both XBMC's uPnP and Samba shares running. WMP worked fine whether I accessed the files via uPnP or Samba.
VLC can see the files in uPnP but will not play them. It will play them via Samba but I think it first copies them to the Windows machine and then plays them.
Sorry I can't be of more use. I'll look into it when I recover the backup SD card:(
Deleted. I can't read the topic.. you said you are using MiniDLNA.
mfcexpert
Look at
http://superuser.com/questions/191736/how-do-i-connect-vlc-to-a-known-dlna-server
There's a reply that reads "In VLC 2.x you can skip the Tools process and directly go to View -> Playlist -> Local Network -> Universal Plug'n'Play to get the DLNA devices on your network listed and stream from them. – Koen Zomers Apr 30 '12"
I did as he says and found that Windows Firewall was blocking access to uPnP. I allowed access and it now seems to work though you have to allow some time for it to settle.
Yatti420
Time for it to settle? I'm confused.. I've verified it's allowed in windows firewall.. It shows up but zero shares..
mfcexpert
It seems you can only access uPnP shares via a (not very well integrated) method. I can't get to them via Media>Open File but only via View>Playlist>Local Network>Universal Plug'n'Play and then wait (20 seconds or so) for the shares to appear. Navigate to the file you want and double-click (or right-click>Play).
It's the best I can do.
Yatti420
The share shows up.. But not any files.. This is typical for me with VLC (windows 7).. Can you confirm the OS you tested on?
