DuaneDibbley
- May 5, 2020
Hi all,
I'm not sure why I need another NAS. I have a pretty happily running DS415+ with 4 of those 6TB Reds with SMR in it
It's okay but it's pretty boring and I'd like to work towards moving my computers which run 24/7 doing various tasks into one box.
Ideally I'd like to build a system which can:
1. Act as remote storage for my wife and I's images in Lightroom - ie store but also work on originals off the NAS = so decent R/W speeds needed.
2. Act as general home bulk storage.
3. Replace my 2012ish Mac Mini server which is running 24/7 with Sonaar, SabNZBd and Plex (with videos stored on synology).
- I could mostly do this with the Synology apart from the poor performance for Plex.
4. Replace Surveillance Station on my Synology with one of the various other options most of which run on Windows like Blue Iris etc.
Initially I plan on using the old 4x 3TB reds I took out of the Synology and replaced with the 6TB ones which won't be suitable for use with ZFS it seems. If this works well I'll increase the capacity and number of drives in the FreeNAS box.
It seems that to accomplish all of that on one machine I need to look at ESXi, various VMs a HBA of some variety to pass through to FreeNAS.
Originally I thought I'd just try building a faster NAS for points 1 & 2 above but then as I looked into it feature creep seems to have really taken hold.. This was my initial "just a NAS" spec:
CPU: Intel Core i3-9100 3.6 GHz Quad-Core Processor
Motherboard: Asus WS C246 PRO ATX LGA1151 Motherboard
Memory: Crucial 16 GB (1 x 16 GB) DDR4-2666 Memory
Storage: Crucial MX500 250 GB M.2-2280 Solid State Drive (For OS or ESXI etc)
Case: Silverstone CS380 ATX Mid Tower Case
Power Supply: SeaSonic FOCUS Plus Platinum 650 W 80+ Platinum Certified Fully Modular ATX Power Supply
= ~$1300 Australian
With the addition of a HBA could I manage to proof of concept with this spec that could potentially be my main server?
I suspect the main weaknesses to be CPU and RAM? More ideally would be 32gb RAM and I'm not sure with the CPU... You gotta spend a LOT on a Xeon before it really seems to outshine the i3 it seems?
I'd probably prefer a Supermicro X11SCM-F (or similar) for the motherboard but it really seems difficult to buy one in Australia for some reason. HBA's are something I know very little about but I think I'm sort of on the right track there - again seems to be less available new and reasonably priced than regular consumer gear. Probably look second hand on ebay - how resilient is ZFS to HBA's exploding due to their owners cheaping out and buying well used?
To go Xeon/HBA/32gb I'm probably looking at around $2000 AU which is quite a lot for a bit of a play/learning experience/hopefully eventually main home NAS/Server.
Please poke any holes you want in my plan! Very keen on hearing input from those with experience and knowing what they're doing :)
= ~$1300 Australian
