Regular home NAS: FD Node 304, Mini-ITX, X11SCL-iF, i3-9100F
Antoshka
Hi everyone,
I'd like to replace my QNAP TS-253Be by a custom NAS.
Main routine: Plex server (average movie is 60Gb), media storage (photos, music, docs), backups and probably light VM with a DB (just a sandbox, not a prod instance). There are only 2 users.
I'm thinking about current setup:
  1. Case: Fractal Design Node 304
  2. Motherboard: Mini-ITX Supermicro X11SCL-iF
  3. CPU: Intel i3-9100F
  4. RAM:16Gb UDIMM x2
  5. Power Supply: EVGA 500 W1
  6. Storage: Couple of WD RED drives (2x10Tb, 1x8Tb - from my current NAS and External drive)
  7. (Optional) CPU Cooler: Noctua NH-L9i
  8. (Optional) HBA Card: LSI SAS 9207-8i
I'd ask to review this config and answer a few questions:
  1. May I use nonECC memory for Supermicro X11SCL-iF + i3-9100F? I've heard that it's possible to use nonECC memory with i3, and it's impossible with Xeon, is it true? I just don't want to spend more money on memory than CPU+Motherboard cost.
  2. I have an extra Samsung 840 Pro 128GB SSD and I planned to use it as OS drive, is it ok?
  3. Market provides a lot of pretty cheap 128Gb NVMe, should I buy one?
  4. Will be this CPU enough for me? (Only one 4K transcoding is possible in my cases)
  5. Should I expect that I can lose some functionality in comparison with QNAP?
  6. Did I miss something?
Thank you in advance.
Antoshka
Hey,
As usual you're finding something necessary/interesting only after already posted message:)
I've spent additional 14 hours on forum(s), youtube, ebay and now I've three others configurations:
Option #1
1) Case: Fractal Design Node 804 (yes, I got that 304 brings a pain with cable management and air flows)
2) Motherboard: Supermicro X11SCL-F
3) CPU: Intel i3-9100F
4) RAM: 16Gb UDIMM x2 (ECC or nonECC)
5) Power Supply: Corsair CX550M
6) Storage: Couple of WD RED drives (2x10Tb, 1x8Tb - from my current NAS and External drive)
7) (Optional) CPU Cooler: Noctua NH-L9i
8) (Optional) HBA Card: LSI SAS 9207-8i
Option #2
2) Motherboard: Supermicro X11SSH-F
3) CPU: Intel Xeon E3 1270 v5
4) RAM: 16Gb ECC UDIMM x2
8) (Optional) HBA Card: LSI SAS 9207-8i (there are 8 SATA ports on motherboard)
Option #3
2) Motherboard: Supermicro X10SLL-F
3) CPU: Intel Xeon E3 1271 v3
4) RAM: 8Gb ECC UDIMM x4
8) (Optional or Mandatory?) HBA Card: LSI SAS 9207-8i (only 2 SATA3 ports...)
Option #1 - most expensive, less powerfull according PassMark, most fresh;
Option #2 - mid expensive, mid powerfull according PassMark, mid fresh;
Option #3 - less expensive, most powerfull according PassMark, less fresh.
I'd really appreciate to any thoughts/comments/suggestions....
Thank you.
Antoshka
It looks more like a monologue, but I'll proceed and probably this info would be helpful to someone.
I've ordered the following configuration:
1) Case: Fractal Design Node 804 (newegg) - 134$
4) RAM: 8Gb ECC UDIMM 1600mhz x4 (ebay combo) - 314$
5) Power Supply: Corsair CX450 (newegg) - 70$
6) Storage: Couple of WD RED drives (2x10Tb, 1x8Tb - from my current NAS and External drive), Samsung 840 Pro 128GB SSD (not sure now for what it will be used) - I've them already
7) (Optional) CPU Cooler: CoolerMaster V4 GTS - I've it already from old PC
8) SATA Cables: 6 Pack 90 Degree Right-Angle SATA III Cable (amazon) - 8$
9) SATA Power Cables (as a workaround for 3.3V SATA drives): 3-Pack 4 Pin Molex to Dual SATA Power Y-Cable (amazon) - 9$
Total: 537$ (without drives)
Probably I'll buy 1-2 SSD drives from ebay for OS or for document storage.
Also I'm going to create a build report.
Thank you.
Antoshka
It's my daily update;)
A few SSD for OS and L2ARC were ordered, so now the configuration is the following (I hope it's a final version and I don't need anything else):
4) CPU Cooler: Intel heatsink from combo OR CoolerMaster V4 GTS (Optional) - I've it already from old PC
5) RAM: 8 Gb ECC UDIMM 1600mhz x4 = 32 Gb (ebay combo) - 314$
6) SAS HBA: LSI 9207-8i PCI-E 3.0 (ebay) - 55$
7) SAS Cable: Mini SAS 36Pin (SFF-8087) Male to 4 SATA 7Pin Female Cable x2 (amazon) - 19$
10) SSD OS: Intel DC S3700 100Gb x 2 (ebay) - 50$
11) SSD L2ARC: Intel DC S3700 400GB (ebay) - 93$
12) SSD VM/Jail: Samsung 840 Pro 128GB - I've it already from old PC
13) HDD Storage: Couple of WD RED drives (2x12Tb, 1x8Tb - from my current NAS and External drive)
Total: 752$ (without HDD)
I think to order 2 more 12 Tb Easystore WD (to have a raidz), but I need to wait until a deal on them.
Thanks!
SweetAndLow
Sweet'NASty
Don't bother with the l2arc, wait until you actually run your system and see if read performance is ok.
Antoshka
Oh, I've ordered already an Intel DC S3700 400GB...
Anyway thank you for the tips!
SweetAndLow
Sweet'NASty
Yeah most people do not need a slog or l2arc device. You can look at zfs-stats -A and your cache hit ratio to see if you would benefit from a l2arc ssd.
Here is what mine looks like with 128GB of memory.
ARC Efficiency
        Cache Access Total:                     1040273500
        Cache Hit Ratio:                94.62%  984347643
        Cache Miss Ratio:               5.37%   55925857
        Actual Hit Ratio:               94.46%  982696393
