Virtual Machine General Questions
Dellyjoe
Hello Everyone,
I just installed my first VM on to my freenas box, Running Ubuntu 20. Atm the only way I can connect up to it is using the VNC however when doing that it is laggy.
Is this the only way that someone can connect to the VM within Freenas?
Thank you for reading,
Joe
Install PuTTY on your PC.
SSH, install your own vnc server like tightvnc, install a product like webmin
Dellyjoe
Sorry @Basil Hendroff I wanted to say I'm looking for a way to better use the VNC program. I like to use Command Line but for the VM i would like the ability to use the GUI. I will start looking into tightvnc thank you @sretalla
Joe
